Nonlinear Inner Iterations Not Using Updated Values
Old   July 24, 2012, 10:32
Default Nonlinear Inner Iterations Not Using Updated Values
Tyler V
tgvosk is on a distinguished road
I am trying to solve a problem which has a nonlinear source term. For simplicity in this example I am not linearizing it. I have defined a function to calculate the explicit source term as
tmp<volScalarField> fSu(volScalarField& y)
    return y + y*y + y*y*y;
and I perform inner iterations (within the time loop) as
while( yRes > resmin )
    volScalarField Su = fSu(y);
    fvScalarMatrix yEqn
        fvm::ddt(y) == fvm::laplacian(y) + Su
    Info<<"Before solve: " << average(y) << endl;
    yEqn.relax();
    lduMatrix::solverPerformance sp = yEqn.solve();
    Info<<"After solve: " << average(y) << endl;
    yRes = sp.initialResidual();
The problem I am having is that the value of y does not seem to update as this iterates. The output of this solve (shown below) seems to use the same value of y to calculate Su each time, rather than using an updated value
Before solve: average(y) [0 0 0 0 0 0 0] 0.0445286
GAMG:  Solving for y, Initial residual = 0.433038, Final residual = 0.0109313, No Iterations 3
After solve: average(y) [0 0 0 0 0 0 0] 0.0444641
(... dozens more times ...)
How can I make the value of the source term be recalculated with the updated values of y? Is there a problem with the way I have defined the source term function?
tgvosk is offline   Reply With Quote
nonlinear iterations, openfoam
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
