Pressure coefficients
Old   December 3, 2008, 11:39
Default hi everybody i'm new of Ope
antonio segalini
antonio_ing is on a distinguished road
hi everybody
i'm new of OpenFOAM and i'm working on the characterization of a NACA 0015 with several turbulence models. Anyway, i really would like to plot the pressure coefficients along the profile. I did a C grid with gmsh with two surfaces (upper & lower) on the profile. The solvers seems right (now i use the Spalart-Allmaras with simpleFoam).
How can i get the values of the pressure at the surface points and the position of those points?
thanks a lot
antonio_ing is offline   Reply With Quote
Old   December 5, 2008, 16:07
Default it works great thanks a lot
antonio segalini
it works great
thanks a lot
cheers
Old   January 13, 2009, 05:06
Default hi everybody i am w
NAVEEN.K.M
naveen is on a distinguished road
hi everybody
i am working on naca 4421 airfoil case...i am facing difficult to give different angles of attack for this airfiol..can u please help me how and where to give AOA in openfoam 1.4.1..
naveen is offline   Reply With Quote
Old   January 13, 2009, 05:13
Default Dear Naveen, Hope you are b
Velan
velan is on a distinguished road
Dear Naveen,
Hope you are beginner to openFOAM. So before trying new cases, why not you try some tutorials in openFOAM. It will build up your basic understandings about openFOAM. All your doubts will clear if you understand the tutorials.
For specifying AOA you have to edit the file "U" under the directory "0". Here you should enter the values of x y z co-ordinates.
velan is offline   Reply With Quote
Old   January 16, 2009, 06:05
Default thanks velan sir for replying.
NAVEEN.K.M
thanks velan sir for replying....
i did naca 0012 airfoil case in gambit and now i need to import it into openfoam 1.4.1...can u please tell me how to import it into openfoam...and also i need naca 0012 vertices to create geometry in openfoam 1.4.1....
Old   January 16, 2009, 06:21
Default How did you created the mesh i
Velan
How did you created the mesh in gambit without its vertices ?
If you have mesh in gambit, then export the mesh in .msh format.
Then copy the mesh into case directory and do
fluentMeshToFoam
There is one nacaAirfoil example in Tutorial(OpenFOAM/OpenFOAM-1.5/tutorials/sonicTurbFoam/nacaAirfoil). Try to understand.
Onemore thing, many people told that post a forum in new thread. Dont spam it. Try to use Start New Thread.
Old   August 1, 2012, 00:20
hfs
hfs is on a distinguished road
Originally Posted by antonio_ing View Post
hi everybody
thanks a lot
Did you get an answer??
I need the same!
Thanks for replying!
hfs is offline   Reply With Quote
Old   August 7, 2012, 14:50
venkat
junkie71189 is on a distinguished road
I need the same!
Hey,
Use paraview and make sure your flow has become steady. Then, in object inspector, choose only the boundary name given to describe the surface of the airfoil and apply. Use the slice filter and slice along the symmetry plane of your mesh. On 're-sizing to fit' you should see only the closed loop around the surface of the airfoil. Choose the variable 'p'. Use the calculator filter to get Cp value and rescale to fit data range. You should be able to see the Cp variation. You can also plot it externally by saving the data to an external file.
Hope this helps!
junkie71189 is offline   Reply With Quote
Old   August 8, 2012, 07:22
hfs
Thank you very much!
Specifying Wind Pressure Coefficients NK FLUENT 0 January 30, 2009 07:32
Pressure coefficients antonio_ing OpenFOAM Post-Processing 1 December 29, 2008 22:01
Problems with pressure coefficients Khoa Kim FLUENT 2 August 26, 2008 08:02
rms of pressure coefficients kbutler FLUENT 0 August 27, 2007 17:20
About the pressure coefficients Wong Phoenics 3 June 11, 2003 16:15
