how can I make sure rhoSimplecFoam NEVER crashes?
Old   September 21, 2012, 17:10
Default how can I make sure rhoSimplecFoam NEVER crashes?
Mihai Pruna
mihaipruna is on a distinguished road
Basically I want it to automatically cut off big numbers, replace divisions by 0 with something else, etc.
I tried relaxation factors and cellLimited gradients.
Is there a way to ensure you get a solution (even inaccurate) , always?
mihaipruna is offline   Reply With Quote
Old   December 25, 2012, 22:55
Haomin Yuan
yhaomin2007 is on a distinguished road
Hi, Mihai
Have you solved your problem, I think I have met the same problem like you.
I am running a simulation with a large area change, which makes the simulation very easy to crash.
Thank you
yhaomin2007 is offline   Reply With Quote
Old   December 27, 2012, 09:12
Mihai Pruna
I had to streamline the geometry further. I was not able to get it to converge on my original model. WIth that, and residuals set to 10E-3, I was able to get it to converge. I had to set residuals this high because divergence occurred after a certain number of iterations. The residuals dropped to a certain level and then they started increasing (p mainly), and then the density would eventually reach either very large or small values, then it would crash.
So, in essence, I have not found a simple solution or a setting that would always ensure convergence just yet.
Old   December 27, 2012, 09:31
Haomin Yuan
Is your flow a pressure driven flow or velocity driven flow? I think you can try time varying condition to get approach the condition you want. And I also suggest you try to decrease the relaxation factor to ensure stable.
Old   December 27, 2012, 11:10
Mihai Pruna
I decided to go with pressure driven flow (total pressure).
In order to prevent my simulation from crashing right away , I had , for the inlet:
type totalPressure;
gamma 1.400000;
rho rho;
p0 uniform 29400.000000;
value uniform 26500.000000;
the 26500 was the static pressure and that was set to fixed at the outlet. I was not able to get the flow to a Mach number above 0.4 without it eventually crashing. Relaxation factors helped a bit.
So, again, it was a combination of factors and tweaks of residuals, relaxation factors, geometry and boundary conditions that yielded a converged solution.
reactingFoam crashes mysteriously jose_rodrig OpenFOAM Running, Solving & CFD 9 August 4, 2015 10:18
[swak4Foam] swak4foam can not be installed hugo17 OpenFOAM Community Contributions 1 September 11, 2012 05:17
flo-efd v11.0.0 crashes YoavF FloEFD, FloWorks & FloTHERM 3 June 21, 2012 12:37
use of Gturbo to make turbine blade usman FLUENT 0 December 31, 2007 05:47
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 18:59
