problem in making a new solver!!!
Like Tree3Likes
  • 1 Post By nimasam
  • 1 Post By ata
  • 1 Post By nimasam
Old   September 25, 2012, 12:30
Default problem in making a new solver!!!
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi everybody,
I'm trying to define a new solver that can solve heat transfer of a viscoelastic fluid, but when I want to made it the following error appeared:
Making dependency list for source file BuoyantBoussinesqViscoelasticFluidFoam.C
could not open file singlePhaseTransportModel.H for source file BuoyantBoussinesqViscoelasticFluidFoam.C
could not open file RASModel.H for source file BuoyantBoussinesqViscoelasticFluidFoam.C
SOURCE=BuoyantBoussinesqViscoelasticFluidFoam.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -I/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/transportModels/viscoelastic/lnInclude -I/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/BuoyantBoussinesqViscoelasticFluidFoam.o
BuoyantBoussinesqViscoelasticFluidFoam.C:38:39: fatal error: singlePhaseTransportModel.H: No such file or directory
compilation terminated.
anybody knows what should I do?
thanks
adambarfi is offline   Reply With Quote
Old   September 26, 2012, 05:43
Nima Samkhaniani
nimasam is on a distinguished road
read error!
#include "singlePhaseTransportModel.H"
adambarfi likes this.
nimasam is offline   Reply With Quote
Old   September 26, 2012, 06:20
adambarfi's Avatar
Mostafa Mahmoudi
thanks Nima,
yes, the Error refer to singlePhaseTransportModel.H but I cannot understand why OF display this error?do you know where is the problem?
Old   September 26, 2012, 07:19
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
You must set the path of the header in the options file in the make folder of your solver under the EXE_INC = \
ata is offline   Reply With Quote
Old   September 26, 2012, 08:46
Retired Super Moderator
Bruno Santos
Greetings to all!
To complement the answers given, check the file "applications/solvers/heatTransfer/buoyantBoussinesqSimpleFoam/Make/options" - online: https://github.com/OpenFOAM/OpenFOAM...m/Make/options
Best regards,
Bruno
Old   September 26, 2012, 08:59
adambarfi's Avatar
Mostafa Mahmoudi
Ata and Bruno, Thank you so much
I changed the option file and the problem solved, but another errors appeared:
In file included from BuoyantBoussinesqViscoelasticFluidFoam.C:51:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:20:6: error: ‘transportProperties’ was not declared in this scope
createFields.H:91:29: error: no match for ‘operator-’ in ‘1.0e+0 - Foam::operator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam::operator-(const Foam::GeometricField<Type1, PatchField, GeoMesh>&, const Foam::dimensioned<Type>&) [with Form = double, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Vector<double>](((const Foam::dimensioned<double>&)((const Foam::dimensioned<double>*)(& TRef))))))))’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dimensionSet.H:255:29: note: candidates are: Foam::dimensionSet Foam::operator-(const Foam::dimensionSet&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dimensionSet.H:263:29: note:                 Foam::dimensionSet Foam::operator-(const Foam::dimensionSet&, const Foam::dimensionSet&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dimensionedScalar.H:52:19: note:                 Foam::dimensionedScalar Foam::operator-(const Foam::dimensionedScalar&, Foam::scalar)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dimensionedScalar.H:53:19: note:                 Foam::dimensionedScalar Foam::operator-(Foam::scalar, const Foam::dimensionedScalar&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalarField.H:78:1: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::scalar&, const Foam::UList<double>&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalarField.H:78:1: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::scalar&, const Foam::tmp<Foam::Field<double> >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalarField.H:78:1: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::UList<double>&, const Foam::scalar&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalarField.H:78:1: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::tmp<Foam::Field<double> >&, const Foam::scalar&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:54:1: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::label&, const Foam::UList<int>&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:54:1: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::label&, const Foam::tmp<Foam::Field<int> >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:54:1: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::UList<int>&, const Foam::label&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:54:1: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::tmp<Foam::Field<int> >&, const Foam::label&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:61:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::UList<Foam::DiagTensor<double> >&, const Foam::UList<Foam::Tensor<double> >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:61:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::UList<Foam::DiagTensor<double> >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:61:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::tmp<Foam::Field<Foam::DiagTensor<double> > >&, const Foam::UList<Foam::Tensor<double> >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:61:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::tmp<Foam::Field<Foam::DiagTensor<double> > >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:64:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::diagTensor&, const Foam::UList<Foam::Tensor<double> >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:64:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::diagTensor&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:64:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::UList<Foam::DiagTensor<double> >&, const Foam::tensor&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/diagTensorField.H:64:1: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::tmp<Foam::Field<Foam::DiagTensor<double> > >&, const Foam::tensor&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/vectorTensorTransformI.H:283:36: note:                 Foam::vectorTensorTransform Foam::operator-(const Foam::vectorTensorTransform&, const Foam::vector&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/quaternionI.H:273:25: note:                 Foam::quaternion Foam::operator-(const Foam::quaternion&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/quaternionI.H:279:25: note:                 Foam::quaternion Foam::operator-(const Foam::quaternion&, const Foam::quaternion&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/septernionI.H:190:25: note:                 Foam::septernion Foam::operator-(const Foam::septernion&, const Foam::vector&)
createFields.H:110:29: error: ‘g’ was not declared in this scope
createFields.H:116:9: error: redeclaration of ‘Foam::volScalarField p’
createFields.H:7:9: error: ‘Foam::volScalarField p’ previously declared here
createFields.H:126:11: error: redeclaration of ‘Foam::label pRefCell’
createFields.H:77:11: error: ‘Foam::label pRefCell’ previously declared here
createFields.H:127:12: error: redeclaration of ‘Foam::scalar pRefValue’
createFields.H:78:12: error: ‘Foam::scalar pRefValue’ previously declared here
In file included from BuoyantBoussinesqViscoelasticFluidFoam.C:80:0:
TEqn.H:12:5: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >)’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: candidates are: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = double]
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double]
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = double]
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = double]
TEqn.H:17:32: error: no match for ‘operator-’ in ‘1.0e+0 - Foam::operator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam::operator-(const Foam::GeometricField<Type1, PatchField, GeoMesh>&, const Foam::dimensioned<Type>&) [with Form = double, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Vector<double>](((const Foam::dimensioned<double>&)((const Foam::dimensioned<double>*)(& TRef))))))))’
BuoyantBoussinesqViscoelasticFluidFoam.C:145:9: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >)’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’
In file included from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricField.C:1270:0,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricField.H:583,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/volFields.H:37,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C:30,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/surfaceInterpolationScheme.H:234,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/surfaceInterpolate.H:41,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvc.H:39,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from BuoyantBoussinesqViscoelasticFluidFoam.C:36:
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C: In function ‘void Foam::subtract(Foam::GeometricField<typename Foam::typeOfSum<Type, Form>::type, PatchField, GeoMesh>&, const Foam::GeometricField<Type1, PatchField, GeoMesh>&, const Foam::dimensioned<Type>&) [with Form = double, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Vector<double>]’:
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:951:1:   instantiated from ‘Foam::tmp<Foam::GeometricField<typename Foam::typeOfSum<Type, Form>::type, PatchField, GeoMesh> > Foam::operator-(const Foam::GeometricField<Type1, PatchField, GeoMesh>&, const Foam::dimensioned<Type>&) [with Form = double, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Vector<double>]’
createFields.H:91:25:   instantiated from here
make: *** [Make/linuxGccDPOpt/BuoyantBoussinesqViscoelasticFluidFoam.o] Error 1
I'm trying to add the Boussinesq assumption to viscoelasticFluidFoam. before I had added temperature to it successfully.
Old   September 26, 2012, 09:02
Nima Samkhaniani
as i said before, read the error line:
1)redeclaration:
you define velocity twice! so omit one of them!!!!
2)you did not define the variable (object) transportproperties at all
so define an "IODictionary"
Old   September 26, 2012, 09:07
adambarfi's Avatar
Mostafa Mahmoudi
1)redeclaration:
you right, when I was editing my last post you reply it, thank you. I edit it.
Old   September 26, 2012, 09:30
adambarfi's Avatar
Mostafa Mahmoudi
I defined a n IODictionary, the following errors appeared:
createFields.H:46:5: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
createFields.H:144:29: error: no match for ‘operator-’ in ‘1.0e+0 - Foam::operator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam::operator-(const Foam::GeometricField<Type1, PatchField, GeoMesh>&, const Foam::dimensioned<Type>&) [with Form = double, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Vector<double>](((const Foam::dimensioned<double>&)((const Foam::dimensioned<double>*)(& TRef))))))))’
Foam::subtract(Foam::Field<Foam::Tensor<double> >&, const Foam::UList<Foam::DiagTensor<double> >&, const Foam::tensor&)
make: *** [Make/linuxGccDPOpt/BuoyantBoussinesqViscoelasticFluidFoam.o] Error 1.
again thank you
Old   September 26, 2012, 10:32
Nima Samkhaniani
two errors:
line 64: error in definition of transportproperties,How did you define this variable?
line 144: i think here you add or abstract an scalar from a dimensionedScalar, its wrong
both type should be dimensioned or use function .value() to use only it's value
Old   September 26, 2012, 15:10
adambarfi's Avatar
Mostafa Mahmoudi
two errors:
Thanks Nima,
I edited the line 64. but I cant understand this error:
createFields.H:163:29: error: ‘g’ was not declared in this scope
createFields.H:169:9: error: redeclaration of ‘Foam::volScalarField p’
createFields.H:179:11: error: redeclaration of ‘Foam::label pRefCell’
createFields.H:130:11: error: ‘Foam::label pRefCell’ previously declared here
createFields.H:180:12: error: redeclaration of ‘Foam::scalar pRefValue’
createFields.H:131:12: error: ‘Foam::scalar pRefValue’ previously declared here
createFields.H:144:25:   instantiated from here
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:951:1: error: no matching function for call to ‘subtract(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::InternalField&, const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::InternalField&, const double&)’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalarField.H:78:1: note: candidates are: void Foam::subtract(Foam::Field<double>&, const Foam::scalar&, const Foam::UList<double>&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/scalarField.H:78:1: note:                 void Foam::subtract(Foam::Field<double>&, const Foam::UList<double>&, const Foam::scalar&)
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:54:1: note:                 void Foam::subtract(Foam::Field<int>&, const Foam::label&, const Foam::UList<int>&)
this is the 144th line:
136    volScalarField rhok
137    (
138        IOobject
139        (
140            "rhok",
141            runTime.timeName(),
142           mesh
143        ),
144        1.0 - beta*(T - TRef)
145   );
Old   September 26, 2012, 16:04
Nima Samkhaniani
1.0 should be defined as dimensioned Scalar
Old   September 26, 2012, 16:12
adambarfi's Avatar
Mostafa Mahmoudi
OK, I fixed it and many other errors. but this error seems to be stronger:
createFields.H:139:29: error: ‘g’ was not declared in this scope
createFields.H:160:9: warning: left-hand operand of comma has no effect
createFields.H:161:45: warning: right-hand operand of comma has no effect
createFields.H:163:9: warning: right-hand operand of comma has no effect
and the 139th line:
138    Info<< "Calculating field g.h\n" << endl;
139    volScalarField gh("gh", g & mesh.C());
140    surfaceScalarField ghf("ghf", g & mesh.Cf());
Old   September 26, 2012, 16:51
Nima Samkhaniani
you should define "g" , as a dimensionedVector
Old   September 26, 2012, 17:29
adambarfi's Avatar
Mostafa Mahmoudi
the error originates from my .C file. in it I had defined the #include "readGravitationalAcceleration.H" after #include "createFields.H". I exchange them with other.
it seems that my solver was made successfully, but when I want to run my model the below error appears:
--> FOAM FATAL ERROR:
    gradientInternalCoeffs cannot be called for a calculatedFvPatchField
    on patch floor of field p in file "/home/mostafa/OpenFOAM/mostafa-2.1.0/run/tutorials/viscoelastic/viscoelasticFluidFoam/Hasan_Giesekus/0/p"
    You are probably trying to solve for a field with a default boundary condition.
    From function calculatedFvPatchField<Type>::gradientInternalCoeffs() const
    in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 186.
FOAM exiting
do you know what should I do?
Old   September 26, 2012, 23:04
Nima Samkhaniani
ok, this error returns to your BC, maybe you define a BC which is not known by OpenFOAM ( look at p file and the BC for floor patch)
Old   September 27, 2012, 14:51
adambarfi's Avatar
Mostafa Mahmoudi
Dear Nima,
I change the boundary condition in p file, but again this error was shown. I delete the p BC file but again this error appeared. do you think the problem is of my solver? it successfully made. do you think that problem is somewhere in fvSolution or fvScheme?!!!
Old   September 29, 2012, 05:48
ata
ata's Avatar
ata kamyabi
Do you use e.g. p=another field or calculate p from other fields during your calculations?
Old   September 29, 2012, 11:56
adambarfi's Avatar
Mostafa Mahmoudi
please see the http://www.cfd-online.com/Forums/ope...ot-called.html thread.
Solver problem in Oscillating Plate tutorial vovogoal CFX 1 November 22, 2011 09:54
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 14:16
Compilation problem after modifying a solver. PetSul OpenFOAM Running, Solving & CFD 2 October 1, 2009 17:28
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 01:26
Wmake problem interFoam solver feijooos OpenFOAM Running, Solving & CFD 4 December 8, 2008 11:01
