October 19, 2012, 09:35 |
Time step independence?
David Gaden
Rep Power: 22 |
Basic stuff here.
I cannot get consistent results from pisoFoam. I have a simple cavity with a cross flow inlet / outlet. I vary the time step from 0.001 to 0.0000001 s and the resulting pressure fields vary by 20-60%. Does anyone have any ideas? So far I've observed:
Yeah, I'm an OpenFOAM developer... not a user. -Dave
~~~ Follow me on twitter @DavidGaden |
October 20, 2012, 21:54 |
Hi David,
are you comparing averaged pressure or just pressure at some time ? Regards, Awais |
October 22, 2012, 06:49 |
Daniel P. Combest
Dave,
Are you sure that there is convergence between all of your fields at each timestep? If not, then this will have a big affect on your pressure field. Adding outer-correction will ensure convergence at each timestep. Have you looked at using pimpleFoam instead of pisoFoam? This is suggested on http://www.cfd-online.com/Forums/ope...ependency.html Last edited by chegdan; October 22, 2012 at 07:01. Reason: edit: bad grammar |
November 5, 2012, 22:50 |
David Gaden
Rep Power: 22 |
@Awais
I am calculating an RMS error across the entire pressure field. Average pressure doesn't vary nearly as much. @Dan Thanks for the suggestions, I will try implementing pimpleFoam into the solver. I've attached some pictures of the pressure and flow field. I'm getting a pressure fluctuation at the inlet, and discontinuities at the corners. I'm sure this is a rookie problem, but it mystifies me. These images are for velocity driven flow. When I do pressure driven flow, though, it smooths out, but I still can't get timestep independence. Thank you all for your suggestions. I will continue troubleshooting this between my full-time job and parenthood! -Dave
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Hydrostatic Pressure and Gravity | miliante | OpenFOAM Running, Solving & CFD | 132 | October 7, 2012 22:50 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
