Solving
Old   October 31, 2012, 14:34
Default Solving
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
Dear All
for solving an external aerodyanmcis prob, i have imported the mesh file from ICEM to ParaFOAM,
and wrote the script as follows..::
The initial velocity U has been set equal to 27.8 m/s in the y direction
at the inlet:
dimensions [0 1 -1 0 0 0 0]; // dimension in m s
internalField uniform (0 0 0);
boundaryField
inlet // inlet patch
type fixedValue;
value uniform (0 27.8 0); // U
The initial turbulent kinetic energy has been set equal to k =
0.02898 m2/s2 at the inlet and outlet (for modeling back flow
turbulence):
dimensions [0 2 -2 0 0 0 0]; // dimension in m
internalField uniform 0.02898;
boundaryField
{ inlet // inlet patch
type fixedValue;
value uniform 0.02898;
outlet // inlet patch
type fixedValue;
The initial dissipation energy rate has been set equal to ε = 1.8239
m2/s3 at the inlet and outlet:
dimensions [0 2 -3 0 0 0 0]; // dimension in m
internalField uniform 1.8239;
boundaryField
inlet
type fixedValue;
value uniform 1.8239;
outlet
type fixedValue;
The initial pressure field P has been set equal to 1 atm everywhere
except at the boundaries where a smooth shape condition is
required. :
dimensions [0 2 -2 0 0 0 0]; dimension in m 2 s -2
internalField uniform 101325;
boundaryField
inlet // inlet type patch (extremity of the conduct)
type zeroGradient; // smooth condition
But, Im not able to run this case. Can any1 plz help me ..?? Its regarding a project and I got stuck here..
sampathevs is offline   Reply With Quote
Old   November 5, 2012, 02:15
treima is on a distinguished road
what does it mean "you arenīt able to run this case"? Where is the problem?
regards
treima
treima is offline   Reply With Quote
Old   November 5, 2012, 02:19
Mam,
Thanks for the response.
and No mam, Im not able to run this case and I dunno wer the problem was..
Can I know ur mail id, so that I wil
mail the whole case files.?? Plz help me out mam.. Im very disappointed with this ..
Old   November 5, 2012, 02:42
Is your mam happy with you?
Which solver? Output? and so on...
openfoam, solving
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
