September 24, 2013, 03:59 |
structure-fluid interaction
maryam morta
Rep Power: 12 |
Dear all
I'd like to model a floating object with mooring lines objected to wave which contains a pneumatic chamber that water can rise and fall in it. So I face with 3 phases( rigid body, water, air).Also, the body moves because of the wave impact. I want to understand the hydrodynamic behavior (diffraction and radiation). I know that there are solvers in openFoam extended for fluid structure interaction. Which solvers are suitable for me and what's their method for solving? I know that Boundary Element Method can do this work well. Is it contained it openFoam? If an image is needed I can put it here. I appreciate any help. |
Fluid structure interaction on baloons | vinz | OpenFOAM Running, Solving & CFD | 38 | September 14, 2016 12:38 |
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 09:30 |
Optimization or fluid structure interaction | Steve_NTUA | Main CFD Forum | 9 | August 29, 2006 03:40 |
Fluid structure interaction | tomm | FLUENT | 2 | September 16, 2004 04:33 |
Fluid Structure Interaction | Gabor Balint | FLUENT | 2 | January 5, 2000 13:08 |
