January 24, 2013, 08:51 |
problems with PlichErdman breakup model
André Zboralski
hallo everyone,
i have a problem with the PilchErdman breakup model. I modified the PilchErdmanCoeffs solveOscillationEq false --> true B1 0,375 --> 0,01; 0,2;1;2 B2 0,236 --> 0,01; 0,2;1;2 to validate a spray model but the droplets and the spray doen´t varry. Does anybody know how to influence the coeffs? |
January 24, 2013, 09:22 |
Adam
Are you getting any droplet breakup at all? Is your Weber number in the range that could cause breakup?
January 24, 2013, 09:44 |
André Zboralski
I Think. Before I calculated by using the ReitzKHRT model. Then I changed to PilchErdmann. I red it should be better for spray modelling. Here are some information about the droplets:
C7H16 dropletsize: d = 0 ...2e-4 m velocity: u = 20 ... 40 m/s --> there must be any droplet breakup!? Is there anything to activate if using PilchErdmann in addition to the selection of the model? Do you know something about the value of the coeffs? |
January 24, 2013, 09:58 |
Adam
Yeah, that should definitely undergo breakup and it looks like your input is correct. Perhaps this bug could be the problem?
http://www.cfd-online.com/Forums/ope...kup-model.html |
January 24, 2013, 10:23 |
André Zboralski
This should be the reason. The first one is the source code of my opanfoam release. Thank You!!! Do you know in which folder I have to do "wmake" to compile?
January 24, 2013, 10:33 |
Adam
The PilchErdman model is in OpenFOAM-2.x.x/src/lagrangian/spray/submodels/BreakupModel/PilchErdman , so as long as you use one of the Allwmake scripts above that directory, it will recompile the contents of that directory. I would run Allwmake from /src/lagrangian.
January 24, 2013, 10:57 |
André Zboralski
Thanks! I will try it and give a feedback!
January 30, 2013, 08:53 |
André Zboralski
It works!!! Thank you!
breakup, coeffs, erdman, pilch |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
non-linear k-epsilon model implementation problems | Saidi | Main CFD Forum | 2 | March 4, 2010 13:23 |
Another breakup model | Jay, Choi | Siemens | 5 | January 13, 2010 13:36 |
atomization model vs breakup model | Jay | Siemens | 7 | January 24, 2008 19:51 |
DPM model w/ Wave model - errors in documentation | HS | FLUENT | 0 | April 12, 2006 04:37 |
