suitable boundary condition for scavenging process? |
January 24, 2013, 17:38 |
Ehsan
Rep Power: 26 |
I have found the cause of errors in my simulation.its at scavenging process.
there is a tube that is filled with internalField: U=0,T=400K,p=250000pa and suddenly one side of it become open to environment.the environment has BC: p0=100000pa and T=288K. I have set various set of BC's for it but I have not obtain correct answer yet.a divergence in e calculation is occured because of decreasing T below 200K. I have examined these sets so far: 1)p:waveTransmissive T and U:zeroGradient Code:
type waveTransmissive; field p; phi phi; rho rho; psi psi; gamma 1.4; fieldInf 100000; lInf .1; value uniform 100000; 2)p:totalPressure T and U:zeroGradient Code:
type totalPressure; p0 uniform 100000; gamma 1.4; rho rho; psi none; 3)p:fixedValue T and U:zeroGradient Code:
type fixedValue; value uniform 100000; 4)p:fixedValue T:fixedValue U:zeroGradient T: Code:
type fixedValue; value uniform 288; Code:
type fixedValue; value uniform 100000; why this simple phenomenon has these difficulties? could anyone give me any help? thanks. Last edited by immortality; January 25, 2013 at 05:34. |
January 25, 2013, 01:11 |
Ehsan
Rep Power: 26 |
any guidance or idea?just a small tube with higher pressure fluid than outside.what's wrong with the modelling?what BC is appropriate? can be linear schemes unstable?
Any thought is appreciated. |
January 25, 2013, 06:48 |
Ehsan
Rep Power: 26 |
fvSchemes:
fluxScheme Kurganov; ddtSchemes { default Euler; ddt(rho) Euler; ddt(rhoU) Euler; ddt(rhoE) Euler; ddt(rho,U) Euler; ddt(rho,e) Euler; ddt(rho,omega) Euler; ddt(rho,k) Euler; } gradSchemes { default none; grad(U) Gauss linear; grad(rho) Gauss linear; grad(rhoU) Gauss linear; grad((1|psi)) Gauss linear; grad(e) Gauss linear; grad(sqrt(((Cp|Cv)*(1|psi)))) Gauss linear; // grad(c) Gauss linear; grad(T) Gauss linear; grad(omega) Gauss linear; grad(k) Gauss linear; } divSchemes { default none; div(tauMC) Gauss linear; div(phi) Gauss linear; div(phi,omega) Gauss linear; div(phi,k) Gauss linear; //div(phiEp) Gauss linaer; //div(phiUp) Gauss linear; //div(sigmaDotU) Gauss linear; } laplacianSchemes { default none; laplacian(muEff,U) Gauss linear corrected; laplacian(alphaEff,e) Gauss linear corrected; laplacian(alpha,e) Gauss linear corrected; laplacian(k,T) Gauss linear corrected; laplacian(DepsilonEff,omega) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; } interpolationSchemes { default none; reconstruct(rho) vanLeer; reconstruct(U) vanLeerV; reconstruct(T) vanLeer; interpolate(rho) linear; interpolate(U) linear; //interpolate(T) linear; //interpolate(e) linear; //interpolate(c) linear; interpolate(rhoU) linear; //interpolate(rPsi) linear; interpolate(muEff) linear; interpolate(tauMC) linear; } snGradSchemes { default none; snGrad(U) corrected; } Code:
solvers { "(rho|rhoU|rhoE)" { solver diagonal; } U { solver smoothSolver; smoother DICGaussSeidel; nSweeps 4; tolerance 1e-11; relTol 0; maxIter 2000; } h { $U; tolerance 1e-12; relTol 0; maxIter 2000; } e { $U; tolerance 1e-12; relTol 0; maxIter 5000; } "(k|omega)" { solver smoothSolver; smoother GaussSeidel; nSweeps 3; tolerance 1e-11; relTol 0; maxIter 2000; } } |
January 25, 2013, 19:10 |
Ehsan
Rep Power: 26 |
does someone know any experiment result of pressures at a scavenging process of a suddenly opened tube to surroundings?
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Pressure Boundary Condition | Matt Umbel | Main CFD Forum | 0 | January 11, 2002 10:06 |
The Boundary Condition about the Flat Plate | boing | Main CFD Forum | 1 | January 6, 2002 16:53 |
