SRF Solution issue with Prism+Tetra mesh compare to Hexa
Old   February 22, 2013, 15:32
Default SRF Solution issue with Prism+Tetra mesh compare to Hexa
Nitin Suryawanshi
suryawanshi_nitin is on a distinguished road
Hi friends,
i m solving a periodic section problem (9.72 deg section) using SRF model, inititally i solved the problem with the pure hexa (coarse- 0.1 million) i got consistent results but now i m trying to add vortex generator on blade, therefore i have to mesh domain with tetra+prism (0.6 million) and i did it, but i m not getting proper results, residuals are also fluctuating, and getting very high velocity on periodic patches. I tried with only tetra also but faced same issue. Even trying with different discretization scheme. Please suggest me the better discretization scheme. can i use hex-core mesh from tgrid to foam....
Thank you In advance....
suryawanshi_nitin is offline   Reply With Quote
Old   February 25, 2013, 12:59
Default inccorect results with tetra compare to hex mesh for the same case
Nitin Suryawanshi
Hi friends,
i m solving a periodic flow problem using SRF model, inititally i solved the problem with the hexa mesh (coarse- 0.1 million) i got good results for various cases, but when same case i m trying with tetra+prism mesh (fine-0.6 million), then i m not getting proper results, residuals are also fluctuating, and getting very high velocity on periodic patches...please help me out...any one has clue regarding these....kindly waiting for reply...
nitin
Old   February 25, 2013, 18:00
Retired Super Moderator
Bruno Santos
Greetings Nitin,
You're not sharing much information on your problem, so it'll be very hard for anyone to help you.
The best I can do to help is give you some sources of information:
Best regards and good luck!
Bruno
Old   February 26, 2013, 15:24
Nitin Suryawanshi
Hi thanks for your reply.. Actually im trying to match results of Case-II (tetra+prism mesh) with Case-I (Hexa mesh).
I m solving a periodic flow problem for fan (Axial entry & radial exit) and i have taken single blade periodic section (from total of 37 blades). Simulation details area as follows:
Case I.) Initialy i tried with hexa mesh (periodic hexa mesh from ICEM):
cell count: 0.09 million
checkMesh: OK for all criterias
Steady state flow
Inlet: velocity inlet (Urel=20.4m/s)
Outlet: pressure outlet (0)
Model: SRFSimpleFoam (as i have only one cell zone i.e. rotating one)
Turbulence Model: SST K-W
Descretization schemes:- grad(p):Gauss linear;
grad(Urel):Gauss linear;
div(phi,Urel) Gauss upwind
laplacianSchemes: Gauss linear corrected
Output: impeller efficiency:57%
Case II) In case-2, I tried with tetra+prism on blade mesh (Periodic mesh)
checkMesh: Number of severly non orthogonal faces:46 and Non-orthogonality check: OK, also remaining checkmesh criterias are ok
Cell count: 0.6 million
"All remaining settings are same like Case-I"
Output: Solution getting diverging and giving very high velocity throughout domain, even though Residuals are dropping below 0.01.
kindly waiting for reply...Thanks in dvance
Nitin
Old   February 27, 2013, 03:58
Bruno Santos
Hi Nitin,
What does checkMesh tell you about the mesh that has tetrahedral cells?
And are you using non-orthogonal correctors?
Best regards,
Bruno
Old   February 27, 2013, 13:06
Nitin Suryawanshi
Hi Bruno, Thanks for your reply, quality check for Tet+Prism mesh is given below,,,,
administrator@ubuntu:~/nitin/ME/ME/results/0.2/1.3tetraFinePrism$ checkMesh
| \\ / O peration | Version: 2.1.1 |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : checkMesh
Date : Feb 27 2013
Time : 12:54:26
Host : "ubuntu"
PID : 2233
Case : /home/administrator/nitin/ME/ME/results/0.2/1.3tetraFinePrism
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1233760
internal faces: 1169262
cells: 594532
boundary patches: 7
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 0
prisms: 24630
wedges: 0
pyramids: 264
tet wedges: 0
tetrahedra: 569638
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
outlet 2256 1297 ok (non-closed singly connected)
inlet 2290 1263 ok (non-closed singly connected)
blade 8210 2137 multiply connected (shared edge)
hub 4986 2841 ok (non-closed singly connected)
shroud 4280 2392 ok (non-closed singly connected)
left1 21238 10836 ok (non-closed singly connected)
right1 21238 10836 ok (non-closed singly connected)
<<Writing 2134 conflicting points to set nonManifoldPoints
Checking geometry...
Overall domain bounding box (-0.0201298 0 -7.68958e-26) (0.0850515 0.306492 0.1787)
Mesh (non-empty, non-wedge) directions (1 1 1)
Boundary openness (1.74928e-19 4.05201e-20 -7.65942e-20) OK.
Max cell openness = 2.21344e-16 OK.
Max aspect ratio = 13.0933 OK.
Minumum face area = 5.08171e-08. Maximum face area = 8.40055e-06. Face area magnitudes OK.
Min volume = 8.5903e-12. Max volume = 7.97833e-09. Total volume = 0.000920781. Cell volumes OK.
Mesh non-orthogonality Max: 78.1445 average: 16.2617
*Number of severely non-orthogonal faces: 42.
Non-orthogonality check OK.
<<Writing 42 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 1.27209 OK.
Coupled point location match (average 1.22399e-11) OK.
Mesh OK.
Time = 1
Mesh stats
faces: 1233760
cells: 594532
boundary patches: 7
point zones: 0
face zones: 1
cell zones: 1
hexahedra: 0
prisms: 24630
wedges: 0
pyramids: 264
tet wedges: 0
tetrahedra: 569638
polyhedra: 0
Point usage OK.
Face vertices OK.
Face pyramids OK.
Mesh OK.
End
In fvSolution file i m using following settings for orthogonal corrector
SIMPLE
nNonOrthogonalCorrectors 0;
Kindly waiting for your reply.
Regards
Nitin
Old   February 27, 2013, 16:57
Bruno Santos
Hi Nitin,
Try setting "nNonOrthogonalCorrectors" to 2:
nNonOrthogonalCorrectors 2;
At least it's what I've seen in the forum...
Nonetheless, these messages:
are a source of concern. The effect of the second one might be reduced with the "nNonOrthogonalCorrectors", but it probably will only reduce the error level by a little bit.
The first one... I don't know. Check if your other mesh had these issues as well or not.
If possible, I would advise you to generate a new mesh with improved quality.
Best regards,
Bruno
Prism mesh Mohankumarg12 ANSYS Meshing & Geometry 7 July 27, 2011 16:10
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 19:39
[ICEM] Hexa Mesh Smoothing Jules ANSYS Meshing & Geometry 6 December 4, 2010 18:00
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
