Patch to Patch mapping
Like Tree2Likes
  • 1 Post By mcdonalds
  • 1 Post By wyldckat
Old   March 6, 2013, 15:13
Default Patch to Patch mapping
Ronald McDonald
mcdonalds is on a distinguished road
Hi OpenFoamers,
I have a really simple question and desire a simple, if possible, response.
I have two boxes connected to each other. I have labelled those adjacent boundaries patch1 and patch2. I have one mesh throughout the whole domain. I want to be able to have two fields throughout the domain, where one ends at patch 1 and the values are transferred onto another field via patch 2. Is this possible in openFoam, if so how can I go about doing this?
Best,
Benjamin
the_ichthyologist likes this.
mcdonalds is offline   Reply With Quote
Old   March 6, 2013, 17:32
Retired Super Moderator
Bruno Santos
Hi Benjamin,
You could have told me in the PM you sent me that you had asked this question here on this thread
Anyway, for other readers, the core of the answer I gave in the private message was:
For your question, I can only think of groovyBC, section 3.6 "Accessing fields from other patches": http://openfoamwiki.net/index.php/Co..._other_patches
Best regards,
Bruno
Old   March 6, 2013, 19:40
Default Thanks, Bruno
Ronald McDonald
Originally Posted by wyldckat View Post
Hi Benjamin,
Best regards,
Bruno
Thanks, Bruno. My bad.
So I think I got the patch to patch mapping working with groovybc. The only thing is I'm getting a light warning message.
HTML Code:
Time = 0.145
--> FOAM Warning :
    From function ExpressionResult::getUniformInternal(const label size,bool noWarn)
    in file ExpressionResult/ExpressionResultI.H at line 322
    The minimum value 999.96 and the maximum 999.96 differ. I will use the average 999.96
DICPCG:  Solving for H2O, Initial residual = 8.52782e-07, Final residual = 8.52782e-07, No Iterations 0
DICPCG:  Solving for H2, Initial residual = 8.11531e-07, Final residual = 8.11531e-07, No Iterations 0
--> FOAM Warning :
Let me know what you think,
Benjamin
Old   March 7, 2013, 08:17
Bruno Santos
Hi Benjamin,
That's one strange warning... there must be something beyond "999.96"... such as "99.96324231235"... but I guess it's perfectly OK.
Best regards,
Bruno
Old   March 7, 2013, 11:51
Ronald McDonald
Hi Bruno,
So I ran my simulation with no boundary patches (the ones I were mapping) and found that my results there are linear. Which is theoretically correct. However, when I try to use groovyBC to combine the two patches I get linear up to the coupled patches then a parabolic after the patch, which is theoretically incorrect. Any ideas on how to solve this?
I heard that pointtopointinterpolation.H is another way to go. I have no idea how to use the header file, however. Any thoughts, and/or direction would be greatly helpful.
Benjamin
Old   March 7, 2013, 16:38
Bruno Santos
Hi Benjamin,
I'm confused... didn't you want to map one field to another different field? Something like mapping "T" to "p" (temperature to pressure) or something like that?
Or do you want to map a single field, e.g. "T", from one patch to another patch?
Best regards,
Bruno
Old   March 7, 2013, 19:06
Ronald McDonald
Hi Benjamin,
Best regards,
Bruno
Hey Bruno,
At first I wanted to do the former, but now I want to do the latter, namely map within a single field one patch to another patch. I've been trying to use patchtopatchinterpolation.H but i haven't been able to get it to work. And groovyBC did work (there's an example of it in the link you provided) but the physics came out incorrectly.
Any help would be great.
Sincerely,
Benjamin
Old   March 8, 2013, 18:18
Bruno Santos
Hi Benjamin,
Right now I don't have time to do any tests, but here is a quick hint - run this command:
grep -R map $FOAM_TUTORIALS
It will give you a list of lines from files in the tutorials that have "map" somewhere in those lines. The keywords to then look for are "mappedField" or similar!
Good luck!
Bruno
Michael@UW likes this.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
