Diverging Simulation using rhoSimplecFoam, kOmegaSST |
January 7, 2013, 16:35 |
Andreas Petrikat
Rep Power: 13 |
Hello everybody,
I have been trying for quite some time to run a compressible simulation of a NACA 0012 profile, using rhoSimplecFoam and kOmegaSST for turbulence modeling. My mesh is unstructured, checkMesh indicates no problems. Running a simulation at Mach 0.7 generates following output: Starting time loop Time = 0.1 GAMG: Solving for Ux, Initial residual = 1, Final residual = 0.0615838, No Iterations 1 GAMG: Solving for Uy, Initial residual = 1, Final residual = 0.0598451, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 27.4647, No Iterations 1000 time step continuity errors : sum local = 0.793546, global = 0.47889, cumulative = 0.47889 rho max/min : 0.1 0.1 GAMG: Solving for h, Initial residual = 0.627704, Final residual = 0.906171, No Iterations 1000 GAMG: Solving for omega, Initial residual = 0.00118687, Final residual = 5.36443e-06, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0494026, No Iterations 2 ExecutionTime = 7.73 s ClockTime = 7 s Time = 0.2 GAMG: Solving for Ux, Initial residual = 0.335287, Final residual = 0.00814846, No Iterations 2 GAMG: Solving for Uy, Initial residual = 0.0892067, Final residual = 0.00223789, No Iterations 2 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" (... ...) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoSimplecFoam" #10 __libc_start_main in "/lib/libc.so.6" #11 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoSimplecFoam" Floating point exception I presume there's something off when calculating for p and h. I have no clue what the problem is though, an incompressible simulation, using simpleFoam and Spallart-Allmaras works fine. Switching transonic off in fvSolution seems to stabilize the simulate at least so much to allow a minimal amount of postprocessing; every single variable diverges massively. Changing the relaxation factors has no significant effect. I am quite new to OpenFoam, and have generated my files according to various threats in this forum as well as to the tutorial cases. Here are my files fvSolution, fvSchemes, p and U. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p0 { solver GAMG; tolerance 1e-10; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } p1 { solver GAMG; tolerance 1e-10; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } p { solver GAMG; tolerance 1e-10; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } omega0 { solver PBiCG; preconditioner DILU; tolerance 1e-10; relTol 0.1; } omega1 { solver smoothSolver; smoother GaussSeidel; nSweeps 1; tolerance 1e-10; relTol 0.1; } omega { solver GAMG; tolerance 1e-10; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } U0 { solver PBiCG; preconditioner DILU; tolerance 1e-10; relTol 0.1; } U1 { solver smoothSolver; smoother GaussSeidel; nSweeps 1; tolerance 1e-10; relTol 0.1; } U { solver GAMG; tolerance 1e-10; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } h0 { solver PBiCG; preconditioner DILU; tolerance 1e-10; relTol 0.1; } h1 { solver smoothSolver; smoother GaussSeidel; nSweeps 1; tolerance 1e-10; relTol 0.1; } h { solver GAMG; tolerance 1e-10; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } k0 { solver PBiCG; preconditioner DILU; tolerance 1e-10; relTol 0.1; } k1 { solver PBiCG; preconditioner DILU; tolerance 1e-10; relTol 0.1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-10; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; rhoMin rhoMin [1 -3 0 0 0] 0.1; rhoMax rhoMax [1 -3 0 0 0] 1.0; transonic yes; pRefPoint (100 0 0); pRefValue 11000; } relaxationFactors { p 0.5; U 0.7; k 0.5; omega 0.5; rho 1; h 0.95; } relaxationFactors0 { p 0.3; rho 0.4; U 0.7; h 0.7; k 0.7; omega 0.7; } // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default fourth; grad(p) fourth; grad(U) Gauss linear; grad(omega) Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; //limitedLinearV 1; //upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,h) Gauss upwind; //limitedLinear 1; //upwind; div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div(phid,p) Gauss upwind; div(U,p) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.5; } interpolationSchemes { default none; interpolate(rho) linear; div(U,p) upwind phi; interpolate((psi*U)) linear; interpolate(U) linear; UD upwind phid; interpolate(p) linear; interpolate(((rho|(A(U)-H(1)))-(rho|A(U)))) linear; interpolate((rho*U)) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; pCorr; } // ************************************************************************* // Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 11000; boundaryField { NONE1 //Nearfield1 { type empty; } NONE2 //Nearfield2 { type empty; } NONE3 //Pressure Side { type zeroGradient; } NONE4 //Nearfield3 { type empty; } NONE5 //Nearfield4 { type empty; } NONE6 //Suction Side { type zeroGradient; } NONE7 //Wake resolution1 { type empty; } NONE8 //Wake resolution2 { type empty; } NONE9 //Trailing Edge { type zeroGradient; } NONE10 //Farfield1 { type empty; } NONE11 //Farfield2 { type empty; } NONE12 //Outer rim, lower half { type freestreamPressure; //type fixedValue; value uniform 11000; } NONE13 //Outer rim, upper half { type freestreamPressure; //type fixedValue; value uniform 11000; } } // ************************************************************************* // Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (239.266 20.933 0); boundaryField { NONE1 //Nearfield1 { type empty; } NONE2 //Nearfield2 { type empty; } NONE3 //Pressure Side { type fixedValue; value uniform (0 0 0); } NONE4 //Nearfield3 { type empty; } NONE5 //Nearfield4 { type empty; } NONE6 //Suction Side { type fixedValue; value uniform (0 0 0); } NONE7 //Wake resolution1 { type empty; } NONE8 //Wake resolution2 { type empty; } NONE9 //Trailing Edge { type fixedValue; value uniform (0 0 0); } NONE10 //Farfield1 { type empty; } NONE11 //Farfield2 { type empty; } NONE12 //Outer rim, lower half { type freestream; freestreamValue uniform (239.266 20.933 0); } NONE13 //Outer rim, upper half { type freestream; freestreamValue uniform (239.266 20.933 0); } } |
January 10, 2013, 02:16 |
Andreas Petrikat
Rep Power: 13 |
*Bump*
Any help would be greatly appreciated |
January 27, 2013, 06:19 |
Hannes Kröger
Rep Power: 18 |
January 27, 2013, 06:37 |
Andreas Petrikat
Rep Power: 13 |
Hey Hannes,
thanks for the reply! Unfortunately, decreasing rhoMin seems to have no effect... |
March 30, 2013, 10:12 |
HECKMANN Frédéric
Rep Power: 16 |
It's a bit late to answer but I often see thread with problems over rhoMin and rhoMax.
Those two values are some "limiters" to avoid unphysical values of rho. This limiter has to be temporary (often at the beginning of the computation to avoid any divergence). You need to know first the freestream value of rho. If you are lazy you can use Wolfram: http://www.wolframalpha.com/input/?i...=&equal=Submit Then you have to choose your rhoMin and rhoMax arround the freestream value. And here you need to be smart and use your experience because the min and max often depend of the geometry. Until Mach 0.5 the density usually change of less than +/- 0.2. |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
