Simple 2D rising Bubble. About B.C. of interFoam.
Old   April 2, 2013, 07:45
Default Simple 2D rising Bubble. About B.C. of interFoam.
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
I want to make a test about rising bubble via interFoam,Its really simple.But what confused me is my B.C. I wish the outlet boundary permit only water getting in and air getting out. so I set alpha B.C. like this:
boundaryField
    sides
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
    frontAndBack
        type            empty;
To maintain stability,I use a combination of p_rgh and U B.C.
P_rgh
boundaryField
    sides
        type            buoyantPressure;
	value		uniform 0;
    inlet
	value		uniform 0;
    outlet
 type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    frontAndBack
	type		empty;
U
boundaryField
   sides
      type            zeroGradient;
    inlet
	type		fixedValue;
	value		uniform (0 0 0);
    outlet
	type            pressureInletOutletVelocity;
  frontAndBack
	type		empty;
It runs normally, and the solution of alpha is not bad.but the p_rgh is little big.you can see the image.
So.if I want to simulate this situation which is only water can getting in,How should I set the B.C.?Thanks in advance.
sharonyue is offline   Reply With Quote
bubbleFoam - Simple case, Large bubble, closed domain darai OpenFOAM Running, Solving & CFD 9 October 12, 2015 05:40
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
Bubble coulmn and VOF method (interFoam) voingiappone OpenFOAM 14 June 26, 2012 20:13
Struggling with BCs for 'simple' interFoam case rassilon OpenFOAM Running, Solving & CFD 1 May 15, 2009 10:16
Single Bubble Gerrit Senger CFX 4 March 12, 2007 16:29
