Water pipe - pressure inlet/outlet - unrealistic velocities
Old   April 10, 2013, 06:24
Default Water pipe - pressure inlet/outlet - unrealistic velocities
Eric
erichu is on a distinguished road
I am running a simple test to verify flow rates of water though a pipe (0.6 m long and 3mm diameter) using known pressures for inlet and outlet.
The inlet has a totalPressure of 106325 Pa and the outlet (fixedValue) 101325 Pa.
The velocity is calculated via pressureInletVelocity.
The kinematic viscosity is set to 1e-6
The current solver is simpleFoam
The experimental flow rate of this setup is around 1 litre per hour --> velocity in flow direction of around 0.04 m/s.
simpleFoam converges in about 1200 iterations but the magnitude of the flow is 99 m/s.
Why is the velocity so high using simpleFoam?
erichu is offline   Reply With Quote
Old   April 11, 2013, 07:08
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Eric,
In simpleFoam what is called pressure is in fact pressure divided by the specific mass (check the units). This may be the cause of the strange results that you've got.
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
