patchExpression with alpha in OF 2.2.0 - calculate heat flux
Like Tree3Likes
  • 2 Post By RMF
  • 1 Post By gschaider
Old   April 18, 2013, 16:31
Default patchExpression with alpha in OF 2.2.0 - calculate heat flux
RMF
RMF is on a distinguished road
I used the patchExpression "alpha)*area()*snGrad(h)" with swak4Foam to monitor the heat flux on a patch in OF 2.1.x. This worked very well. Since I have updated to OF 2.2.0 I get an error "Parser Error for driver PatchValueExpressionDriver at "1.2-3" :"field alpha not existing or of wrong type.
Has anybody an idea how to acces the thermal diffusivity in OF 2.2.0 in a patchExpression? Or does anybody know another way to monitor the wallHeatFlux.
Thanks
RMF
RMF is offline   Reply With Quote
Old   April 22, 2013, 17:36
Assistant Moderator
Bernhard Gschaider
Thanks
RMF
Seems you became a victim of the improvement of the thermodynimc classes. Didn't have much time to look at it, but when looking at the part where alpha is declared I see
alpha_
        IOobject
            phasePropertyName("thermo:alpha"),
            mesh.time().timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
Guess that means that it is now called thermo:alpha with the name of the phase in front. The bad thing is not that I don't know which phaseName should be prefixed in your case, the bad thing is that I don't think that swak accepts ":" as a valid part of a field name and this will need some work on the parser to make him accept it (because currently it is part of the ?:-operator)
Will look at this as soon as I find the time. Bug report might speed it up
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 24, 2013, 08:11
RMF
This is what I found out as well in the meantime: alpha is called thermo:alpha (I used the "bananas"-trick with a wirteRegisteredObject). But as you've assumed, swak4Foam does not accept the ":" in thermo:alpha.
For those, who have a similar problem:
As a workaround I modified the solver and registered an additional field alpha, which is updated at the end of each timestep with the values from thermo:alpha. This is probably inefficient, but it is working for the moment. If there are any better ideas, I'd be glad to hear them.
I will report a bug and hope you will find the time to modify swak4Foam in the near future. Anyway, thank you for your answer.
Bye RMF
Old   April 24, 2013, 20:19
Assistant Moderator
Bernhard Gschaider
I added a feature to swak where you can define aliases for such "unusual" field names like this
aliases {
  alpha thermo:alpha;
With that you can say "alpha" in your expression and "thermo:alpha" will be used. I'll push that to the public development-repository in the next days (just have to check it doesn't break anything) and of course it will be in the next release
Old   April 28, 2013, 19:03
Assistant Moderator
Bernhard Gschaider
aliases {
  alpha thermo:alpha;
OK. It is pushed to the mercurial repository
Old   May 2, 2013, 03:49
RMF
Thank you very much. You were really quick. But it's still not working for me (maybe it's my fault):
I changed my function to
HeatLoss
type patchExpression;
patches (CAVITYIN CAVITYBACK);
verbose true;
aliases {
alpha thermo:alpha
expression"(alpha+alphat)*area()*snGrad(h)";
accumulations (sum);
but now I get the error message:
No field of type scalar with the name alpha found
Fields of type: volScalarField
17
thermo:mu
Something changed, but it's still not working...
Did I use the aliases wrong? The other variation I tested led to the old error message.
Bye RMF
apple-tree and mgg like this.
Old   May 4, 2013, 06:23
Assistant Moderator
Bernhard Gschaider
HeatLoss
verbose true;
aliases {
alpha thermo:alpha
17
thermo:mu
Bye RMF
No that looks alright. Must check. Which solver which version are you using?
Old   May 4, 2013, 08:05
RMF
I am using the buoyantSimpleFoam solver of OF 2.2.0
Thanks
Bye RMF
Old   May 4, 2013, 17:46
Assistant Moderator
Bernhard Gschaider
Thanks
Bye RMF
Seems like the aliasing wasn't added to ALL relevant functions. A fix is now pushed to the development repository on sourceforge
lth likes this.
Old   May 15, 2013, 12:50
RMF
Sorry for the late reply: I was busy last week...but I now I had some time to test your modification. It's working now. Thank you very much!
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Wall Heat Flux & Temperature Greg Perkins FLUENT 10 November 20, 2015 09:32
Radiation interface hinca CFX 15 January 26, 2014 17:11
heat flux distribution gtheo CFX 2 April 27, 2011 03:36
monitoring dynamic heat flux through a surface abdnakhi FLUENT 0 August 15, 2005 09:57
