Jack Lee
Rep Power: 13 ![]() |
I want to inject fine solid particles into a flow. I know that Chalmers already have solidParticles tutorials but I am not interested in injecting a few particles and I want to use/ modify the existing solvers such as coalChemistryFoam. My biggest questions would be : 1) If I want a constant mass flow rate of total mass flow, mtot in a duration of t how do I specify my massflowrate profiles? 2) How does the nParcelsperSecond input comes into play and how do I calculate how many parcel I want ? 3) As I want to inject solid particles, preferably of one size or diameter, how do I specify that? Most of the size distribution models such as Rosin-Rammler are made for droplets, (if not mistaken) and hence, it allows a range of particle sizes. But how do I fix them? Should I use uniform distribution and if so, what do I put in the (x , y ) list? THank you very much for anyone's input and I will deeply appreciate it if anyone can answer these questions accurately. Jack |
lagrangian particles, spray simulation |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
multiphase -solid particles | nikolaous | Fluent Multiphase | 3 | June 11, 2013 14:49 |
interaction between solid and fluid particles | agastyamit | CFX | 5 | November 17, 2011 07:56 |
injection particles | zenith | FLUENT | 0 | April 3, 2007 00:56 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
