Problem running OpenFOAM 2.2.x in parallel in Centos 5 |
May 16, 2013, 18:36 |
Laura Alvarez
Can you please help me with this problem?
I am trying to run OpenFOAM 2.2.x in parallel. I am working in a Centos 5 supercomputer. I am trying to run a very simple case from the tutorials called damBreak in parallel. And when I type: mpirun -np 4 interFoam -parallel The following error pop up: It looks like opal_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during opal_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): opal_shmem_base_select failed --> Returned value -1 instead of OPAL_SUCCESS -------------------------------------------------------------------------- [saguaro1.local:22583] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file runtime/orte_init.c at line 79 [saguaro1.local:22583] [[INVALID],INVALID] ORTE_ERROR_LOG: Error in file orterun.c at line 694 |
May 17, 2013, 15:43 |
Niels Nielsen
Rep Power: 27 |
Hi try with these extra input to mpirun
Also check that its using the openfoam mpirun and not the system mpirun. You can check this by sourcing the OF environment and then do Code:
which mpirun Code:
mpirun -np 4 -x LD_LIBRARY_PATH -x PATH -x WM_PROJECT_DIR -x WM_PROJECT_INST_DIR -x WM_OPTIONS -x FOAM_LIBBIN -x FOAM_APPBIN -x FOAM_USER_APPBIN -x MPI_BUFFER_SIZE interFoam -parallel
Linnemann PS. I do not do personal support, so please post in the forums. |
May 17, 2013, 16:55 |
Laura Alvarez
Hi Linnemann,
Thank you for your prompt response. Indeed it is using open mpirun. Code:
which mpirun ~/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/openmpi-1.6.3/bin/mpirun But, I am still getting the same error when I do: Code:
mpirun -np 4 -x LD_LIBRARY_PATH -x PATH -x WM_PROJECT_DIR -x WM_PROJECT_INST_DIR -x WM_OPTIONS -x FOAM_LIBBIN -x FOAM_APPBIN -x FOAM_USER_APPBIN -x MPI_BUFFER_SIZE interFoam -parallel -------------------------------------------------------------------------- It looks like opal_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during opal_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): opal_shmem_base_select failed --> Returned value -1 instead of OPAL_SUCCESS -------------------------------------------------------------------------- Thank you. Laura |
May 17, 2013, 17:13 |
Laura Alvarez
I personally think that this is a bug in the centfoam distribution rather than something specific to the supercomputer environment.
May 17, 2013, 17:59 |
#5 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Laura: Quote:
AFAIK, there are two possible solutions that should give the best results:
Bruno
May 18, 2013, 15:47 |
Niels Nielsen
Rep Power: 27 |
Hi
I installed a virtual machine and found the same problem with mpirun. To fix it you need to have the system gcc and gcc-c++ installed. Otherwise you will get a compile error. So here comes the fix Code:
rm -rf $FOAM_EXT_LIBBIN/../../linux64Gcc/openmpi-1.6.3 cd $FOAM_INST_DIR/ThirdParty-2.2.x ./Allwmake cd $FOAM_SRC/Pstream/dummy wclean cd ../mpi wclean cd .. ./Allwmake I will have a centFoam version up with the fixes, but it will take some time to upload etc.
May 20, 2013, 13:54 |
Laura Alvarez
Linnemann,
Thank you very much for your help. I follow your instructions and it worked for me as well. Best. Laura |
May 20, 2013, 17:50 |
anonymous
It seems I'm experiencing the same problem.
I have updated from 2.1.x to 2.2.x (git repository / Third Party 2.2.0) on Debian Wheezy in a small 3 node cluster on thze master node. While so far everything works on the master node with its 8 cores in parallel, I get the above described error as soon as a i define the other nodes in the hostfile. I hoped that I get it fixed quickly by following the instructions of linnemann, but this was unfortunately not the case in my situation. The same error occured again. The installation is only on the central master node, all paths are defined correctly to access openFoam executables on the master node. This worked fine on the 2.1.x and previous installations. I have checked the paths configuration for openmpi and get by "which mpirun" from all nodes the same correct path of the 2.2.x installation. I also checked and confirmed that I can start from each node OF executables on the master node. Any suggestions and help is higly welcome!!! Best Regards, Peter |
May 21, 2013, 17:57 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Peter: I guess you ignored post #5 More specifically, the second bullet point. I say this because from your description, it looks like you've been using the Open-MPI versions that are distributed with OpenFOAM. Problem is that OpenFOAM 2.2 provides Open-MPI 1.6.3, which might act/build in a different way from the older versions. Therefore, if you use the Debian's own Open-MPI version, you shouldn't have any more problems. Since you're using Debian Wheezy, I think you can take a look at these instructions that are directed towards installing OpenFOAM 2.2.0 on Ubuntu 12.04: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04 - more specifically steps #1, #3 and #4... Best regards, Bruno
May 23, 2013, 08:49 |
#10 | |
Many thanks for your help! I just want to let you know that this fix worked for me as well (centFOAM on centOS 6.4). Cheers, |
May 25, 2013, 11:24 |
#11 |
anonymous
@ Bruno,
thank`s a lot for your suggestion. Obviously Debian Wheezy has problems with openmpi 1.6.3 or viceversa. Following your proposal, to use Wheezy`s own openmpi (1.4.5), fixed the problem. I changed to: "export WM_MPLIB= SYSTEMOPENMPI" in "OpenFOAM-2.2.x/etc/bashrc", recompiled and after that it worked. Best Regards, Peter |
August 1, 2013, 11:35 |
#12 |
Niels Nielsen
Rep Power: 27 |
New versions of centFoam is now up that fixes the problem, but also has all the newest git pull from the 01-08-2013.
August 30, 2013, 10:06 |
#13 | |
Rob Gordon
Rep Power: 12 |
October 9, 2013, 00:01 |
#14 |
Dr. B T KANNAN
I have seen my friend using OpenFOAM with few nodes in cluster, with one node as master and other nodes as slaves. (Rocks & CentOS)
-- KANNAN |
October 17, 2013, 08:57 |
Problem with Centfoam
#15 |
Aditya
@linnemann
Hello linnemann I am facing the same problem with the latest download of CentFoam 6.x which as pre source forge is updated on 20-08-2013. But the problem persists. I also noticed that now the version of MPI is 1.7.2 rather than 1.6.3 for which the method to solve the problem is defined. Regards Aditya |
October 18, 2013, 04:54 |
#16 |
Niels Nielsen
Rep Power: 27 |
Hi
Just replace 1.6.3 with 1.7.2 in the how to get it to work. I still dont know why this error happens after it gets unpacked on a different machine.
March 11, 2014, 08:48 |
#17 |
D. N. Venturi
I've got same problem with manual installation of centFOAM OpenFOAM-2.3.x for CentOS 6
The solution presented by linnemann didn't work for me. I'll try the python installation with centFOAM.py --OF22 and see if it works |
May 9, 2014, 10:23 |
#18 |
Rep Power: 12 |
Hi!
I found somewhere the command: unset LD_PRELOAD which solved the problem for me. |
June 11, 2014, 02:39 |
#19 |
Rep Power: 12 |
I'm trying to run OpenFoam 2.3.0 in parallel on CentOS 6.2 and I have the same problem described in the original post. I have already tried all the above proposed solutions like changing the build options to use the system's openmpi and recompiling, however the following message keeps coming up: It looks like opal_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during opal_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): opal_shmem_base_select failed --> Returned value -1 instead of OPAL_SUCCESS Everything works fine in serial simulation. I'd like to ask if someone who had the same problem found another workaround and managed to run OpenFoam 2.3 in parallel. Thanks alot in advance, Greg |
June 28, 2014, 15:28 |
#20 |
Bruno Santos
Rep Power: 128 |
Greetings Greg and welcome to the forum!
If you could provide more information on how you've proceeded to perform the installation of OpenFOAM 2.3.0 on your machine, it would help to start diagnosing why you're getting that error message. In addition, have a look at the following thread for more diagnostic steps: http://www.cfd-online.com/Forums/ope...-2-centos.html Best regards, Bruno |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
Problem in running job in parallel | Tarak | OpenFOAM | 0 | March 19, 2011 20:34 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 05:07 |
Running Problem using Openfoam solver | cfd_staruser | OpenFOAM | 5 | August 14, 2009 02:28 |
