(1|A(U)) in twoPhaseEulerFoam
Old   May 22, 2013, 15:53
Default (1|A(U)) in twoPhaseEulerFoam
L. Y.
Aurora is on a distinguished road
Dear Foamers,
I have been trying to use the twoPhaseEulerFoam solver, but when I set up my own case, I often encounter the error message "request for volscalarfield (1|A(U)) failed" for no obvious reason.
This is confusing because the velocities used in this solver are Ua and Ub, corresponding to the two phases separately, and there should not be U in this solver...
This is how I specified Ua (Ub is similar):
boundaryField
liquidInlet
type fixedValue;
value uniform (0 0 0);
leftGasInlet
type fixedValue;
value uniform (0.191831 -0.0442808 0);
rightGasInlet
type fixedValue;
value uniform (-0.0862924 0.176956 0);
outlet
type zeroGradient;
walls
type fixedValue;
value uniform ( 0 0 0 );
Any suggestions on how to solve this would be highly appreciated!
Thanks
Aurora is offline   Reply With Quote
Old   May 22, 2013, 15:59
L. Y.
Btw, I was able to get the solver to work on a 2D mesh with the same type of boundary conditions, but I'm having problem with a 3D case now with the above-mentioned error.
Error, running a modified version of twoPhaseEulerFoam foamer OpenFOAM Running, Solving & CFD 0 March 11, 2012 16:17
Something wrong in UEqns.H within twoPhaseEulerFoam cheng1988sjtu OpenFOAM 2 June 24, 2011 10:48
twoPhaseEulerFoam freemankofi OpenFOAM 0 May 23, 2011 16:24
Stratified flow using twoPhaseEulerFoam karthik1414 OpenFOAM 4 May 4, 2011 05:12
stratified horizontal two phase flow usinfg twoPhaseEulerFoam karthik1414 OpenFOAM 0 April 12, 2011 09:57
