June 4, 2013, 05:44 |
Flow around cube and cube natural convection
Amin
Hello everyone,
I am a new OpenFoam user and have tried to understand since 3 weeks, how OpenFoam is working. That's why i decided like to simulate a flow around cube and also cube natural convection and i hope that this topic will help the new user of OpenFoam. I chose a cube because it is simple geometry, the solver Code:
simpleFoam Code:
buoyantPimpleFoam I am not sure, if Code:
buoyantPimpleFoam Here is my blockMeshDict-File Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | Author: Amine Abd. | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0)//0 (1 0 0)//1 (2 0 0)//2 (3 0 0)//3 (3 1 0)//4 (3 2 0)//5 (3 3 0)//6 (2 3 0)//7 (1 3 0)//8 (0 3 0)//9 (0 2 0)//10 (0 1 0)//11 (1 1 0)//12 (2 1 0)//13 (2 2 0)//14 (1 2 0)//15 (0 0 0.5)//16 (1 0 0.5)//17 (2 0 0.5)//18 (3 0 0.5)//19 (3 1 0.5)//20 (3 2 0.5)//21 (3 3 0.5)//22 (2 3 0.5)//23 (1 3 0.5)//24 (0 3 0.5)//25 (0 2 0.5)//26 (0 1 0.5)//27 (1 1 0.5)//28 (2 1 0.5)//29 (2 2 0.5)//30 (1 2 0.5)//31 ); blocks ( hex (0 1 12 11 16 17 28 27) (20 20 10) simpleGrading (1 1 1) //1 hex (1 2 13 12 17 18 29 28) (20 20 10) simpleGrading (1 1 1) //2 hex (2 3 4 13 18 19 20 29) (20 20 10) simpleGrading (1 1 1) //3 hex (13 4 5 14 29 20 21 30) (20 20 10) simpleGrading (1 1 1) //4 hex (14 5 6 7 30 21 22 23) (20 20 10) simpleGrading (1 1 1) //5 hex (15 14 7 8 31 30 23 24) (20 20 10) simpleGrading (1 1 1) //6 hex (10 15 8 9 26 31 24 25) (20 20 10) simpleGrading (1 1 1) //7 hex (11 12 15 10 27 28 31 26) (20 20 10) simpleGrading (1 1 1) //8 ); edges ( ); boundary ( outlet { type patch; faces ( (3 4 20 19) (4 5 21 20) (5 6 22 21) ); } inlet { type patch; faces ( (9 10 26 25) (10 11 27 26) (11 0 16 27) ); } fixedWalls { type wall; faces ( (14 13 29 30) (12 15 31 28) (14 15 31 30) (12 13 29 28) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
blockMesh Code:
Creating block mesh topology --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 901 Found 22 undefined faces in mesh; adding to default patch. Than i typed Code:
simpleFoam SimpleFoam seems to work : Code:
Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } Creating finite volume options No finite volume options present SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0726962, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0521262, No Iterations 4 time step continuity errors : sum local = 3.66569, global = -2.27357e-13, cumulative = -2.27357e-13 smoothSolver: Solving for nuTilda, Initial residual = 1, Final residual = 0.0803582, No Iterations 2 ExecutionTime = 0.84 s ClockTime = 1 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.651251, Final residual = 0.0381755, No Iterations 4 GAMG: Solving for p, Initial residual = 0.811213, Final residual = 0.0665551, No Iterations 2 time step continuity errors : sum local = 12.6457, global = -2.88632e-13, cumulative = -5.15989e-13 smoothSolver: Solving for nuTilda, Initial residual = 0.268523, Final residual = 0.011164, No Iterations 4 ExecutionTime = 1.36 s ClockTime = 1 s Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.291545, Final residual = 0.0170455, No Iterations 4 GAMG: Solving for p, Initial residual = 0.78304, Final residual = 0.0427918, No Iterations 2 time step continuity errors : sum local = 16.3457, global = -1.55024e-13, cumulative = -6.71013e-13 smoothSolver: Solving for nuTilda, Initial residual = 0.182843, Final residual = 0.0105602, No Iterations 4 ExecutionTime = 1.82 s ClockTime = 2 s Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.112318, Final residual = 0.00632812, No Iterations 4 GAMG: Solving for p, Initial residual = 0.580159, Final residual = 0.028626, No Iterations 2 time step continuity errors : sum local = 12.9383, global = -2.60342e-13, cumulative = -9.31355e-13 smoothSolver: Solving for nuTilda, Initial residual = 0.158829, Final residual = 0.0102358, No Iterations 4 ExecutionTime = 2.29 s ClockTime = 2 s Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.21411, Final residual = 0.0126197, No Iterations 4 GAMG: Solving for p, Initial residual = 0.44336, Final residual = 0.0152502, No Iterations 2 time step continuity errors : sum local = 5.62188, global = -2.35846e-13, cumulative = -1.1672e-12 smoothSolver: Solving for nuTilda, Initial residual = 0.146856, Final residual = 0.00996576, No Iterations 4 ExecutionTime = 2.82 s ClockTime = 3 s Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.240414, Final residual = 0.0148877, No Iterations 4 GAMG: Solving for p, Initial residual = 0.456608, Final residual = 0.0263508, No Iterations 2 time step continuity errors : sum local = 8.80232, global = -2.33654e-13, cumulative = -1.40086e-12 smoothSolver: Solving for nuTilda, Initial residual = 0.14195, Final residual = 0.0100417, No Iterations 4 ExecutionTime = 3.31 s ClockTime = 3 s Time = 7 smoothSolver: Solving for Ux, Initial residual = 0.126614, Final residual = 0.00789634, No Iterations 4 GAMG: Solving for p, Initial residual = 0.398651, Final residual = 0.0255971, No Iterations 2 time step continuity errors : sum local = 7.84955, global = -1.63525e-13, cumulative = -1.56438e-12 smoothSolver: Solving for nuTilda, Initial residual = 0.139509, Final residual = 0.010145, No Iterations 4 ExecutionTime = 3.81 s ClockTime = 4 s Time = 8 smoothSolver: Solving for Ux, Initial residual = 0.111525, Final residual = 0.0060335, No Iterations 4 GAMG: Solving for p, Initial residual = 0.338563, Final residual = 0.0178897, No Iterations 2 time step continuity errors : sum local = 5.31132, global = -1.2965e-13, cumulative = -1.69403e-12 smoothSolver: Solving for nuTilda, Initial residual = 0.138472, Final residual = 0.0102371, No Iterations 4 ExecutionTime = 4.35 s ClockTime = 4 s Time = 9 smoothSolver: Solving for Ux, Initial residual = 0.0770265, Final residual = 0.00430644, No Iterations 4 GAMG: Solving for p, Initial residual = 0.287078, Final residual = 0.0179152, No Iterations 2 time step continuity errors : sum local = 5.35135, global = -1.76606e-13, cumulative = -1.87064e-12 smoothSolver: Solving for nuTilda, Initial residual = 0.138024, Final residual = 0.0103762, No Iterations 4 ExecutionTime = 4.81 s ClockTime = 5 s Time = 10 smoothSolver: Solving for Ux, Initial residual = 0.053643, Final residual = 0.00339355, No Iterations 4 GAMG: Solving for p, Initial residual = 0.253213, Final residual = 0.014103, No Iterations 2 time step continuity errors : sum local = 4.29403, global = -2.67682e-13, cumulative = -2.13832e-12 smoothSolver: Solving for nuTilda, Initial residual = 0.137795, Final residual = 0.0104911, No Iterations 4 ExecutionTime = 5.29 s ClockTime = 5 s End Code:
ERROR: In /home/kitware/Dashboards/MyTests/ParaView-master/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0x1d9f0f0): boundaryField defaultFaces not found in object U at time = 0 ERROR: In /home/kitware/Dashboards/MyTests/ParaView-master/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0x1d9f0f0): boundaryField defaultFaces not found in object nuTilda at time = 0 ERROR: In /home/kitware/Dashboards/MyTests/ParaView-master/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0x1d9f0f0): boundaryField defaultFaces not found in object nut at time = 0 ERROR: In /home/kitware/Dashboards/MyTests/ParaView-master/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0x1d9f0f0): boundaryField defaultFaces not found in object p at time = 0 do you have any idea, how to solve this problem ? I need your Support Thanks. |
June 4, 2013, 08:04 |
Amin
Hello everyone,
I removed my paraview, which i downloaded from paraview.org and i installed the paraview from this website http://www.openfoam.org/download/ubu..._0-1_amd64.deb (source http://www.openfoam.org). The simulation is now working, but i got this Error: p, li { white-space: pre-wrap; } Code:
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0xf7ef40): boundaryField defaultFaces not found in object nuTilda at time = 0 ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0xf7ef40): boundaryField defaultFaces not found in object nut at time = 0 ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0xf7ef40): boundaryField defaultFaces not found in object p at time = 0 I need your Support Thanks. Last edited by Mirage12; June 14, 2013 at 01:24. |
June 9, 2013, 08:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Amin,
Well this is indeed a bit strange... OK, so the first diagnostic is that your mesh only defines 3 patches: "outlet", "inlet" and "fixedWalls". blockMesh then tells you that all of the other faces that you did not specify patches for them, it associated automatically all of them to the default patch name "defaultFaces". Then, since you were not aware of this, you only defined boundary conditions for the patches you knew about. In addition, it seems that you have set-up the case to run with a "laminar" transport model, therefore the fields "nut", "k", "epsilon" and so on are not used by the solver, nor did you configure them accordingly. In the end, the problem you get from ParaView is that it is not aware that the fields "nut", "k", "epsilon" are to be ignored. The trick is to not select them in the selection box "Volume Fields". Now, the strange thing is about the "p" field. simpleFoam seemed to open the file "0/p" just fine, or perhaps it completely ignored it... either way, the patch name "defaultFaces" should be missing from it, which is why ParaView complained. Best regards, Bruno
June 12, 2013, 09:23 |
Amin
Hello Bruno,
Thanks for support I solved the problem. The initialization of my boundaries was not correct. here ist the correct blockMeshDict File: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | |Attachment 22688 | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | Author: Amine Abd. | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0)//0 (1 0 0)//1 (2 0 0)//2 (9 0 0)//3 (9 1 0)//4 (9 2 0)//5 (9 3 0)//6 (2 3 0)//7 (1 3 0)//8 (0 3 0)//9 (0 2 0)//10 (0 1 0)//11 (1 1 0)//12 (2 1 0)//13 (2 2 0)//14 (1 2 0)//15 (0 0 1)//16 (1 0 1)//17 (2 0 1)//18 (9 0 1)//19 (9 1 1)//20 (9 2 1)//21 (9 3 1)//22 (2 3 1)//23 (1 3 1)//24 (0 3 1)//25 (0 2 1)//26 (0 1 1)//27 (1 1 1)//28 (2 1 1)//29 (2 2 1)//30 (1 2 1)//31 ); blocks ( hex (0 1 12 11 16 17 28 27) (40 40 5) simpleGrading (1 1 1) //1 hex (1 2 13 12 17 18 29 28) (40 40 5) simpleGrading (1 1 1) //2 hex (2 3 4 13 18 19 20 29) (90 40 5) simpleGrading (6 1 1) //3 hex (13 4 5 14 29 20 21 30) (90 40 5) simpleGrading (6 1 1) //4 hex (14 5 6 7 30 21 22 23) (90 40 5) simpleGrading (6 1 1) //5 hex (15 14 7 8 31 30 23 24) (40 40 5) simpleGrading (1 1 1) //6 hex (10 15 8 9 26 31 24 25) (40 40 5) simpleGrading (1 1 1) //7 hex (11 12 15 10 27 28 31 26) (40 40 5) simpleGrading (1 1 1) //8 ); edges ( ); boundary ( inlet { type patch; faces ( (9 10 26 25) (10 11 27 26) (11 0 16 27) ); } outlet { type patch; faces ( (3 4 20 19) (4 5 21 20) (5 6 22 21) ); } fixedWalls { type wall; faces ( (28 29 13 12) (29 30 14 13) (30 31 15 14) (31 28 12 15) (0 1 17 16) (1 2 18 17) (2 3 19 18) (8 9 25 24) (7 8 24 23) (6 7 23 22) ); } frontAndBack { type empty; faces ( (1 0 11 12) (2 1 12 13) (2 3 4 13) (4 13 14 5) (5 14 7 6) (14 15 8 7) (15 10 9 8) (12 11 10 15) (16 17 28 27) (17 18 29 28) (18 19 20 29) (20 21 30 29) (21 22 23 30) (30 23 24 31) (31 24 25 26) (28 31 26 27) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (25.75 3.62 0); boundaryField { inlet { type freestream; freestreamValue uniform (25.75 3.62 0); } outlet { type freestream; freestreamValue uniform (25.75 3.62 0); } fixedWalls { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } // ************************************************************************* // Last edited by Mirage12; June 14, 2013 at 01:11. |
June 14, 2013, 01:23 |
Amin
Hello everyone,
In order to visualize the velocity and pressure, that i used the option #Plot over the Line# in ParaView. ( SEE THE ATTACHMENTS) I'd like to plot the velocity, Reynolds number and pressure in only one point over the time and the variation of the Reynolds number over the Line. Any idea, how to plot in only one point the velocity, Reynolds number,pressure, drag and lift over the time?? Thanks Last edited by Mirage12; June 14, 2013 at 03:09. |
June 15, 2013, 11:20 |
Bruno Santos
Rep Power: 128 |
Hi Amin,
Check this post: http://www.cfd-online.com/Forums/par...tml#post405615 - post #2 The key filter explained there is "Plot selection over time" and that post also explains one way for selecting a specific point. Best regards, Bruno
FLUENT LES Simulation of flow past a cube | NGH | FLUENT | 6 | November 13, 2012 23:45 |
Natural convection model | sieginc. | STAR-CCM+ | 4 | April 23, 2012 04:20 |
natural convection in stratifeid zone | cfdlame | Main CFD Forum | 3 | December 1, 2011 03:37 |
How to Determine BC's for Natural Convection | Ken Adams | FLUENT | 15 | June 15, 2010 11:31 |
Natural convection at a cube | Michael | Main CFD Forum | 6 | June 25, 1999 10:39 |
