May 19, 2008, 08:51 |
People from here,
How do
Thiago Reis Carvalho Cabral Miliante
Rep Power: 17 |
People from here,
How do I access each phase property? Like rho, mu and nu? In my case for air and water, which I've set in the transportProperties file. Thanks in advance. miliante. |
May 19, 2008, 19:44 |
which solver?
try below
dime
which solver?
try below dimensionedScalar rho(transportProperties.lookup("rho")); or dimensionedScalar rho; rho=dimensionedScalar(transportProperties.lookup(" rtho")); Su Junwei |
June 19, 2013, 07:55 |
ABE
Rep Power: 13 |
Hi Junwei,
I need to call twoPhaseProperties inside a turbulence model (k omega sst). I mean inside ' void kOmegaSSTRebound::correct()' How would it be possible? I have tried the following but wiothout success. const dimensionedScalar& rho1 = transport_.rho1(); or dimensionedScalar rho1(transportProperties.subDict("phase1").lookup( "rho")); |
June 19, 2013, 08:35 |
Nima Samkhaniani
Rep Power: 24 |
did you introduce following objects:transport_ , transportProperties in your code?
if not, then how do you want to call a member of it?
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
June 19, 2013, 08:52 |
ABE
Rep Power: 13 |
Hi Nimasam,
Thanks for your comment. The rho1, and rho2 can be called through twoPhaseProperties. And if one follows the hierarchy (creatFields.H, then turbulenceModel.C, then RansModel.C, and finally kOmegaSST.C), it can be seen that twoPhaseProperties has passed inside the kOmegaSST.C by the name of 'transport': kOmegaSST::kOmegaSST ( const volVectorField& U, const surfaceScalarField& phi, transportModel& transport, const word& turbulenceModelName, const word& modelName ) However, I do not still know how to use it. Any comment is highly appreciated. ABE |
June 20, 2013, 05:04 |
#6 | |
Nima Samkhaniani
Rep Power: 24 |
you can use following structure to read from dict:
Question of properties in two phase solver | mmjhuang | OpenFOAM Running, Solving & CFD | 2 | October 29, 2012 22:56 |
UDF help on accessing values | shashikant | FLUENT | 0 | December 22, 2005 09:41 |
Accessing flow properties at certain points inUDFs | nicolas | FLUENT | 2 | February 14, 2005 20:42 |
Accessing material properties in UDF | Henrik Widell | FLUENT | 0 | March 18, 2002 09:49 |
UDF & Accessing Turbulence Properties | Dimal | FLUENT | 0 | March 5, 2002 13:14 |
