Can't run a case in HelyxOS with an imported mesh from Fluent |
July 2, 2013, 06:25 |
Rep Power: 12 |
Hello;
I have just started to use HelyxOS to see if it's worthy to get into it and use for many purposes instead of Fluent, but I'm not able even to run a simple case. The main purpose is to do a fluent mesh and then to convert it. I have done it already and I can see it properly with paraFoam, so, the mesh is OK. What I have is the case folder where there is: Case Folder Constant polyMesh (with all the converted files) system controlDict I load the case with HelyxOS; I see the mesh and I have access to the Case Setup tab. I set everything up and when I click on Start to run the case, this is all I get: First it saves a lot of files related to the case setup. Then I get: Exception in thread "Thread-4" java.lang.NullPointerException at eu.engys.core.project.system.SystemFolder.save(sys temFolder.java:124) And it gets stuck there... nothing ever happens after that. Any advice or comment whould be very helpfull. Thank you very much!! |
helyx-os, openfoam, running |
[ICEM] Tips for 3D tetra mesh quality for Fluent transient run. Rotary Engine | Catthan | ANSYS Meshing & Geometry | 0 | June 18, 2012 12:46 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Please help I need Fluent 6 tutorial mesh and case files... | bbcorrozojr | FLUENT | 2 | May 7, 2009 04:38 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
