Axial fan SimpleFoam with fvOptions, time step continuity errors
Old   August 6, 2015, 11:47
Default Axial fan SimpleFoam with fvOptions, time step continuity errors
Clement Mtrl
Clmkite is on a distinguished road
Hi everyone,
I'm trying to determine performances of an axial fan.
Profil naca4412 and 36 blades.
First, I tried with the solver SRFSimpleFoam but my results seemed to be innacurate.
So I want to try with multiple frame with simpleFoam and FvOptions and it wil be a good training also because I strat OpenFoam recenttly.
My mesh is 10deg sectors with one blade ond cyclicAMI boundaries.
Inlet : 10m.s-1
rot : 900RPM
My problem is that my time step continuity errors go very high (e+90) !
You can fin the whole case here
Link to case : folders and mesh
and here there is boundarys, fvschemes, u and p fields;
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
10
    inlet
        type            patch;
        nFaces          78;
        startFace       5460135;
    outlet
        type            patch;
        nFaces          70;
        startFace       5460213;
    outerwall
        type            wall;
        inGroups        1(wall);
        nFaces          146;
        startFace       5460283;
    cycl1stat
        type            cyclicAMI;
        inGroups        1(cyclicAMI);
        nFaces          6286;
        startFace       5460429;
        transform       rotational;
        neighbourPatch  cycl2stat;
        rotationAxis    (0 0 1);
        rotationCentre  (0 0 0);
    cycl2stat
        type            cyclicAMI;
        nFaces          6286;
        startFace       5466715;
        neighbourPatch  cycl1stat;
    cycl1rot
        type            cyclicAMI;
        nFaces          7417;
        startFace       5473001;
        neighbourPatch  cycl2rot;
    cycl2rot
        type            cyclicAMI;
        nFaces          7417;
        startFace       5480418;
        neighbourPatch  cycl1rot;
    innerwallrot
        type            wall;
        inGroups        1(wall);
        nFaces          150;
        startFace       5487835;
    innerwallstat
        type            wall;
        inGroups        1(wall);
        nFaces          446;
        startFace       5487985;
    blade
        type            wall;
        inGroups        1(wall);
        nFaces          89034;
        startFace       5488431;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            uniformFixedValue;
        uniformValue    0;
    outerwall
        type            zeroGradient;
    innerwallrot
        type            zeroGradient;
    innerwallstat
        type            zeroGradient;
    blade
        type            zeroGradient;
    cycl1stat
        type            cyclicAMI;
    cycl2stat
        type            cyclicAMI;
    cycl1rot
        type            cyclicAMI;
    cycl2rot
        type            cyclicAMI;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 10);
    outlet
        type            inletOutlet;
        value           $internalField;
        inletValue      uniform (0 0 0);
    outerwall
        type            slip;
    innerwallrot
        type            slip;
    innerwallstat
        type            slip;
    blade
        type            fixedValue;
        value           uniform ( 0 0 0 );
    cycl1stat
        type            cyclicAMI;
    cycl2stat
        type            cyclicAMI;
    cycl1rot
        type            cyclicAMI;
    cycl2rot
        type            cyclicAMI;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss limitedLinearV 1;
    div(phi,k)      bounded Gauss limitedLinear 1;
    div(phi,epsilon) bounded Gauss limitedLinear 1;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Also, if you have have any recommandations I'd be glad to hear it.
Thanks a lot
Clmkite is offline   Reply With Quote
Old   August 10, 2015, 11:05
maHein is on a distinguished road
cyclicAMI should be specified as "nonRotatingPatches" in fvOptions:
MRF1
    type            MRFSource;
    active          true;
    selectionMode   cellZone;
    cellZone        rotor;
    MRFSourceCoeffs
        active      true;
        origin      (0 0 0);
        axis        (0 0 1);
        omega       -90;
        nonRotatingPatches
            cycl1stat
            cycl2stat
            cycl1rot
            cycl2rot
It should work then.
Kind regards,
Martin
maHein is offline   Reply With Quote
Old   August 11, 2015, 15:15
Clement Mtrl
Hi Martin,
Thanks a lot for your answers.
You solved this porblems.
I still have some convergence problems but for now I'm trying to solve them by myself.
Regards,
Clement
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
