Fatal Error in decomposePar
Old   July 18, 2013, 08:20
Default Fatal Error in decomposePar
Sira
Ronan is on a distinguished road
I'm runnung the code in parallel, no probs with openFoam 2.0.1 version but when Im running with openFoam 2.2.1 I got this error:
--> FOAM FATAL IO ERROR:
Cannot find 'value' entry on patch inlet of field U in file "/(...)/0/U"
which is required to set the values of the generic patch field.
(Actual type timeVaryingUniformFixedValue)
Please add the 'value' entry to the write function of the user-defined boundary-condition
file: /(...)/0/U.boundaryField.inlet from line 27 to line 29.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file genericFvPatchField/genericFvPatchField.C at line 71.
FOAM exiting
Any idea how to solve the problem?
Thanks
Ronan is offline   Reply With Quote
Old   July 18, 2013, 10:15
Sira
Solved! it was becuase timeVaryingUniformFixedValue is not more used in 2.1.X
Old   July 23, 2013, 08:06
Basta
mina.basta is on a distinguished road
I have this message:
size 2629 is not equal to the given value of 14752
file: /home/fayez/Bureau/test1_clapet/0/ccz::boundaryField::stlSurface_entree from line 3386031 to line 3386032.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
Anybody can help me to solve it?
mina.basta is offline   Reply With Quote
Old   July 23, 2013, 08:33
Artem Shaklein
ARTem is on a distinguished road
It seems, in ccz variable in boundary field description (0/ folder) you set
value nonuniform List<Type> 2629(....);
but according to a mesh (constant/polyMesh/) that boundary has 14752 faces instead of 2629.
ARTem is offline   Reply With Quote
Old   August 16, 2013, 10:31
Retired Super Moderator
Bruno Santos
Greetings to all!
To add to ARTem's answer: the files "0/cc*" usually can safely be removed, since those are only useful for debugging and certain cases of dynamic meshes.
Best regards,
Bruno
descomposepar, error
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 08:57
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 05:27
decomposePar: can use this decomposition method only for the whole mesh aloeven OpenFOAM Bugs 0 March 16, 2011 10:15
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
