InterDymFoam FloatingObject Modification(Help!) |
Youngkook Kim
Rep Power: 12 ![]() |
Hi all,
I'm a beginner of OPENFOAM and trying to learn InterDymFoam modifying FloatingObject. Now I'm trying to set a case that an object is initially in the air and drops to water. I have changed: 1. topoSetDict : location of box box (0.35 0.35 0.54) (0.65 0.65 0.76); 2. setFieldsDict : initial free surface is level box ( -100 -100 -100 ) ( 100 100 0.4 ); Calculation stops at about 0.3s. I've tried to reduce deltaT to 0.0001 but still stops at below. Post-processing results up to 0.2s look okay. I didn't change much except above and deltaT, hence, writeControl is adjustableRunTime. Please advise what I should try. Thank you!! Interface Courant Number mean: 0.0034416063622 max: 6.74414777876 Courant Number mean: 0.00989467176837 max: 6.74414777876 deltaT = 9.54914388697e-006 Time = 0.349705 Centre of mass: (0.49998781966 0.50001274756 0.227535688399) Linear velocity: (-0.000159344840514 0.00016488321201 -0.541114919706) Angular velocity: (0.000263342477032 -2.71499290814e-005 4.04946967898e-006) GAMG: Solving for cellDisplacementx, Initial residual = 0.000521751846108, Fina l residual = 9.10599745783e-006, No Iterations 4 GAMG: Solving for cellDisplacementy, Initial residual = 0.000489321994054, Fina l residual = 8.72499674845e-006, No Iterations 4 GAMG: Solving for cellDisplacementz, Initial residual = 0.00063944853338, Final residual = 5.03910294448e-006, No Iterations 5 Execution time for mesh.update() = 1.031 s time step continuity errors : sum local = 0.000338450048206, global = -1.6928321 7593e-013, cumulative = -0.000389941435316 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.2383126360 8e-006, No Iterations 6 time step continuity errors : sum local = 0.00333300621618, global = -3.65868127 703e-009, cumulative = -0.000389945093997 MULES: Solving for alpha1 Phase-1 volume fraction = -1.17557007983e+290 Min(alpha1) = -8.6426155539e+294 Max(alpha1) = 2.58348481221e+294 |
floatingobject, interdymfoam |
Stability Issue with interDyMFoam / floatingObject tutorial | ccmccomb | OpenFOAM Running, Solving & CFD | 4 | April 27, 2023 04:13 |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
problems with interDyMFoam | alexm | OpenFOAM Running, Solving & CFD | 4 | March 5, 2015 15:09 |
Problem with FloatingObject | Leech | OpenFOAM Running, Solving & CFD | 10 | March 29, 2012 15:24 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
