Open channel flow with interFoam
Like Tree2Likes
  • 1 Post By sorockin
Old   August 2, 2013, 11:20
Default Open channel flow with interFoam
Maxim Sorockin
sorockin is on a distinguished road
Dear Foamers, I need some help.
I try to simulate flow in open channel with interFoam. I use setting from wigleyHull tutorial. I only changed the geometry of channel and inlet velocity (0.25 m/s). But I see instability in simulated results. Tel me please what need to change to get flow without instabilities. Screenshots of alpha, U and case setup are attached.
Thanks a lot!
Maxim
kraf likes this.
sorockin is offline   Reply With Quote
Old   August 3, 2013, 11:36
Default New settings
Maxim Sorockin
I have moved form LTSInterFoam to interFoam and changed turbulence values setting. I think that problem with stability was in time constraints or wrong turbulent settings.
Now I use interFoam with maxCo=0.5 and maxAlphaCo=0.5.
I set internalField and inlet value for k from expression k=1.5*(U*I)^2. U=0.25, turbulence intensity I put 1%. So k=9.375e-6.
For mega - from expression omega=Cm^(-0.25)*k^0.5/L, Cm=0.09, turbulence length I put 7% of channel depth. So omega=5.324e-3.
I deleted nut file in 0/ folder to OpenFOAM calculate nut values.
But I still have flow instability.
Help me please I am new in OpenFOAM and don't know what needs to do!
New case setting are attached.
Maxim
JFM likes this.
Old   August 5, 2013, 08:35
Default laminar
Maxim Sorockin
If I turn off turbulence and simulate laminar flow I still obtain instability. What is the cause? Solution scheme or boundary condition? But I took boundary conditions from wigleyHull tutorial. I am confused.
Maxim
Old   August 6, 2013, 08:34
David GISEN
David* is on a distinguished road
The second case doesn't look bad in my opinion. You set turbulence at the inlet, and you get turbulence.
In the third case the reason might be some BC.
If you say instability one thinks of numerical instability. You can check it via the residuals. In the forum there is a script for gnuplot that processes the values given in your .log-file (if you write a .log-file).
David* is offline   Reply With Quote
Old   August 6, 2013, 09:41
Maxim Sorockin
Thank you for reply David!
I used initial setting from "wigleyHull" tutorial. "wigleyHull" used turbulence model too but flow is much more uniform. I simulated this case with flow3D (k-epsilon turbulence model, the same mesh) and had uniform flow.
How nice it would be to know exactly what it is - BC or solution scheme.
It is good idea, thank you!
Maxim
Old   August 6, 2013, 10:30
Default laminar, changed setup
Maxim Sorockin
I changed setup for laminar simulation. I moved from 3D to 2D (xz plane) and divided inlet plane. Onto inlet and wall.
So now I have channel 85x1x17 m with mesh 340x1x170. Water depth is 15m.
With BCs:
inlet
U: fixedValue; value uniform (0.25 0 0);
alpha1: fixedValue; value uniform 1;
p_rgh: zeroGradient;
inletWall
U: symmetryPlane;
alpha1: symmetryPlane;
p_rgh: symmetryPlane;
outlet
U: zeroGradient;
alpha1: zeroGradient;
atmosphere
U: pressureInletOutletVelocity; phi phi; value uniform (0 0 0);
alpha1: inletOutlet; inletValue uniform 0; value uniform 0;
p_rgh: totalPressure;
bottom
U: symmetryPlane;
I still have "instability" at inlet. It may be connected with wrong inlet BC. I will be glad any advice. The case is attached.
Maxim
Old   August 7, 2013, 11:24
Default Mesh, BC or schems
Maxim Sorockin
I made another changes.
My mesh had dx/dz ratio 2.5. I made dx=dz to remove mesh as one of cause that may induce instability.
Then I changed BCs, accordingly Matthew Denno
http://www.cfd-online.com/Forums/ope...lowing-up.html
inlet
p_rgh: buoyantPressure; value uniform 0;
inletWall
U: fixedValue; value uniform (0 0 0);
outlet
U: inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0);
p_rgh: inletOutlet; inletValue uniform 0; value uniform 0;
atmosphere
U: pressureInletOutletVelocity; value uniform (0 0 0);
bottom
And I still have "instability" that arise at inlet and then result strongly nonuniform flow.
I tried different "working" BC set from another threads but "instability" didn't disappeared.
May be deal in solution schemes. Can anybody help me? Please!
Maxim
Old   August 9, 2013, 10:14
Default fvSolution
Maxim Sorockin
I took fvSolution setting from Matthew case and looks like "instability" disappeared.
Thank you Matthew for helpful post!
Maxim
Old   October 20, 2013, 06:50
Default Mattew Case
JFM
JFM's Avatar
John Anonymous
JFM is on a distinguished road
Send a message via Skype™ to JFM
Hi Maxim
You refer to Matthew's case in the post above, can you provide a link to this.
Thanks
JFM
JFM is offline   Reply With Quote
channel flow, instability, interfoam
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
No fluid in open channel flow VOF flow_CH Fluent Multiphase 2 July 2, 2013 01:05
OpenFOAM open channel flow downsteam boundary condition Brickman OpenFOAM Running, Solving & CFD 2 November 5, 2012 20:14
Open Channel Flow forsumit FLUENT 0 October 1, 2009 02:01
