Injector Atomization with LES-VOF, modelling approach? |
August 6, 2013, 09:50 |
Kshitij kunte
Hi All,
I need to simulate atomization with of the liquid jet inside a cylindrical nozzle. The image of geometry is attached. I'm giving a fluid at the inlet with velocity of 50 m/s where the diameter of the inlet is 0.6 mm. The throat has a diameter of 0.2mm. Initially the air at high pressure(5.2e6 Pa) and temperature (900 K) is in the domain with no fluid. The flow is considered to laminar incompressible, Newtonian and isothermal flow. The fluids are completely immiscible. Can anyone give me suggestions about modelling this. |
LES + VOF + Particle tracking | mittal | OpenFOAM | 0 | June 29, 2010 06:41 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
LES & VOF | ahmadkariminia | FLUENT | 1 | May 12, 2004 04:34 |
Moving mesh or VOF? | Giovanni | Main CFD Forum | 16 | September 24, 2001 08:25 |
upwind schemes,zonal grids and LES | Prabhu | Main CFD Forum | 5 | October 20, 1999 19:43 |
