August 8, 2013, 03:59 |
compressibleInterFoam diverges after restart
Stefan Hildenbrand
Rep Power: 16 |
Hi all,
I am running a compressibleInterFoam case starting from t=0 which seems to be running and converging nicely (see log_0.01.txt). In order to change the number of processors I stopped the simulation and made a restart. Unfortunately, after this restart I immediately get strange values of p_rgh and after a few more iterations the computation crashes (see log_cont_run.txt - I stopped before the crash occurs). I also attached the logfile in the case I do not interrupt my computation (log_without_break.txt) I am simulating the outflow of a liquid out of a car door sill. The viscosity of the liquid is temperature-dependant, therefore I modified compressibleInterFoam such that an additional (temperature-dependant) transport model is available. I attached my 0.org directory - note that I use a time-dependant BC for Temperature, if I had not used it, my computation would have crashed immediately. Before I start the run I do a mapFields where I impose starting conditions for "alphawater" and "T". My "main"-BCs are: alphawater: constantAlphaContactAngle p_rgh: fixedFluxPressure p: calculated T: uniformFixedValue U: fixedValue I can not post the geometry, however in case this helps, I attached a 2D-sketch of the door sill. I hope I have supplied all necessary information to make my point - if you need more details, please tell me. Does anyone have an idea where my mistake is? Stefan 0.org.zip log_0.01.txt log_cont_run.txt log_without_break.txt IMG_0310.jpg |
compressibleinterfoam, crash, p_rgh, restart |
Can't restart 2-way FSI using ANSYS 14.0 Workbench | MSHowes | ANSYS | 2 | July 3, 2014 13:30 |
Problem at restart | abonfi | SU2 | 3 | May 2, 2013 13:43 |
Problem with multiframe restart of two-way fsi coupled problem | Dimone | CFX | 26 | December 20, 2011 10:10 |
Restart for solidification | atulverma | FLOW-3D | 2 | May 15, 2009 06:25 |
v4 restart bug | optima prime | Siemens | 3 | February 2, 2009 22:51 |
