problem in running parallel: ./Allrun: 62: shift: can't shift that many
Like Tree2Likes
  • 1 Post By wyldckat
  • 1 Post By Astrodan
Old   August 17, 2013, 05:03
Default problem in running parallel: ./Allrun: 62: shift: can't shift that many
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody
I've been used parallel running till this morning. I restart my system and when I want to run my case in parallel, which I had ran it in parallel this morning correctly, It said:
Create time
Time = 0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod scotch
Finished decomposition in 0.12 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Processor 0
    Number of cells = 7513
    Number of faces shared with processor 1 = 90
    Number of faces shared with processor 2 = 112
    Number of processor patches = 2
    Number of processor faces = 202
    Number of boundary faces = 15228
Processor 1
    Number of cells = 7493
    Number of faces shared with processor 0 = 90
    Number of faces shared with processor 2 = 150
    Number of processor faces = 240
    Number of boundary faces = 15168
Processor 2
    Number of cells = 7494
    Number of faces shared with processor 0 = 112
    Number of faces shared with processor 1 = 150
    Number of processor faces = 262
    Number of boundary faces = 15204
Number of processor faces = 352
Max number of cells = 7513 (0.173333% above average 7500)
Max number of processor patches = 2 (0% above average 2)
Max number of faces between processors = 262 (11.6477% above average 234.667)
Processor 0: field transfer
Processor 1: field transfer
Processor 2: field transfer
End.
I'm so confused!!!!
anyone knows where is the problem?
I attach the decomposeParDict file.
thanks
Mostafa
File Type: gz decomposeParDict.tar.gz (498 Bytes, 8 views)
adambarfi is offline   Reply With Quote
Old   August 17, 2013, 06:11
Baris (Heewa)
shipman is on a distinguished road
try following descriprtion, i think that it will work. In the use of scotch u shoul also define the processorWeights. it work fine with my calculations
[CODE]
numberOfSubdomains 3;
method scotch;
scotchCoeffs
processorsWeights
1
1
1
shipman is offline   Reply With Quote
Old   August 17, 2013, 10:53
Retired Super Moderator
Bruno Santos
Greetings to all!
@Mostafa: Well, you didn't exactly indicate the error message in particular, only on the title itself, which isn't much information.
My guess is that you copied the case folder from one place to another and in the new location, somewhere, there is a name with a space in it.
Best regards,
Bruno
Old   August 17, 2013, 11:47
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
dear Bruno,
the error is:
as you see in my last post there isnt any error in running decomposepar but in terminal the above message is shown.
I changed the sort of solving my equations and it worked!!! I had been solving Ueqn, Teqn, Ceqn, peqn. I changed the sort to Ueqn, peqn, Teqn, Ceqn and it worked!!!
do you know what is the reason???
thank you
Mostafa
Old   August 17, 2013, 11:56
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Mostafa
which solver you use?see the solved code if the order is important or not.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 17, 2013, 12:25
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by immortality View Post
Hi Mostafa
Hi Ehsan,
I'm using a modified buoyantBoussinesqSimpleFoam.
my case was ran in usual way but when I want to run it in parallel it failed.
Old   August 17, 2013, 12:27
Bruno Santos
What was the exact command you tried to use in the Allrun script for running in parallel?
Old   August 17, 2013, 12:36
adambarfi's Avatar
Mostafa Mahmoudi
Dear Bruno,
#!/bin/sh
cd ${0%/*} || exit 1    # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
application=`getApplication`
#runApplication $application
runApplication decomposePar
runParallel $application 3
runApplication reconstructPar
streamFunction
foamToTecplot360
Old   August 17, 2013, 12:43
Bruno Santos
OK, now we're getting somewhere
That error you got is related to this line:
It can give you that error you got if:
  • the "$application" variable is empty;
  • or if the number "3" is missing;
  • or is you accidentally had "$application3";
  • or if the value inside "$application" was "buoyantBoussinesqSimpleFoam2" or "buoyantBoussinesqSimpleFoam-cookies". This value would come from the "system/controlDict", defined in the keyword "application".
Best regards,
Bruno
adambarfi likes this.
Old   August 17, 2013, 12:58
adambarfi's Avatar
Mostafa Mahmoudi
thank you Bruno for your quick reply.
as I refer in the http://www.cfd-online.com/Forums/ope...tml#post446313 post, with changing the sort of equation my problem solved, but I cannot understand why this message is shown?
Old   May 11, 2015, 09:31
Timm Severin
Astrodan is on a distinguished road
For anyone coming here via google, this might be related to a "bug" in the RunFunctions tools, where tab characters in dictionaries are not accepted as whitespace separators between option-name and option-value
(See: http://www.openfoam.org/mantisbt/view.php?id=1689)
wyldckat likes this.
PhD Student at the Institute of Biochemical Engineering at TU München
Modelling of fluid dynamics in open photobioreactors.
System:
OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation
Astrodan is offline   Reply With Quote
OpenFoam Parallel running shipman OpenFOAM Running, Solving & CFD 3 August 17, 2013 10:50
Problem in Running OpenFoam in Parallel himanshu28 OpenFOAM Running, Solving & CFD 1 July 11, 2013 09:19
Running in parallel Djub OpenFOAM Running, Solving & CFD 3 January 24, 2013 16:01
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 05:07
