Difference between solvers
Old   August 17, 2013, 11:16
Default Difference between solvers
Gabriel de PInho RImoli
Grimoli is on a distinguished road
Is there any difference between chtMultiRegionSimpleFoam and chtMultiRegionFoam??
At this time im using the simplefoam,but I was figuring what implements i could get if I use the regionFoam.Any suggestions??
Grimoli is offline   Reply With Quote
Old   August 17, 2013, 15:05
Retired Super Moderator
Bruno Santos
Greetings Gabriel,
If you check the User Guide, namely the section 3.5: http://www.openfoam.org/docs/user/standard-solvers.php
You'll see these descriptions:
Originally Posted by www.openfoam.org/docs/user/standard-solvers.php
chtMultiRegionFoam
Combination of heatConductionFoam and buoyantFoam for conjugate heat transfer between a solid region and fluid region
Steady-state version of chtMultiRegionFoam
As for getting started with the chtMultiRegion*Foam solvers, my advice is to study this tutorial: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D
Best regards,
Bruno
Solid Mechanics Solvers added to OpenFOAM Extend bigphil OpenFOAM Announcements from Other Sources 26 October 12, 2017 04:01
Possible turbulence modelling bug in SRF solvers otm OpenFOAM Running, Solving & CFD 3 May 29, 2012 04:03
Reaction solvers megacrout OpenFOAM 5 July 8, 2011 10:54
the effect of upwind difference hades Main CFD Forum 8 March 14, 2009 23:43
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 22, 2005 23:49
