January 7, 2021, 06:26 |
Radiation heat source in chtMultiRegion
julien
Rep Power: 7 |
I try to implement a heat source to take into account the external radiation from the ambient temperature on the interface between solid to fluid regions of a very simple test case using chtMultiRegionFoam solver. My fvOption in the /solid directory is below: HTML Code:
temperatureLimit
type limitTemperature;
active true;
limitTemperatureCoeffs
selectionMode all;
min 290;
max 10000;
heatSource
type scalarCodedSource;
active true;
name sourceTime;
scalarCodedSourceCoeffs
selectionMode all;//cellSet
//cellSet externalRadiationcell;
fields (h);
// fieldNames (T);
redirectType sourceTime;
// name sourceTime;
codeInclude
codeCorrect
Pout<< "**codeCorrect**" << endl;
codeAddSup
const scalar rhomat = 7850;
const scalar emi = 0.9;
const scalar Cp = 450;
const scalar sigma = 5.670374e-8;
const scalar Trad = 1000;
const volScalarField& T = eqn.psi(); // sans cette ligne erreur
scalarField& hSource = eqn.source(); //defining source
// Iterating through patch
word solid_to_fluid = coeffs().lookupOrDefault<word>("patch", "solid_to_fluid");
const fvPatch& pp = mesh().boundary()[solid_to_fluid];
forAll(pp, i) {
label cell_i = pp.faceCells()[i];
scalar Ai = pp.magSf()[i];
scalar Ts = T[cell_i];
hSource[cell_i] = sigma*emi*(pow4(Ts)-pow4(Trad))*Ai/rhomat/Cp;
// Pout << V << endl; // retourne 3200 cells avec un volume de 0.00025 m3 soit 0.8m3 dans log
// le cellSet comporte 400 cells soit 0.1 m3
Pout << "***codeAddSup***" << endl;
Pout << hSource << endl;
// Pout << pp.magSf() << endl; // retourne la surface d'une cell 0.01m2
codeSetValue
// Pout<< "**codeSetValue**" << endl;
// Dummy entry. Make dependent on above to trigger recompilation
code
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue
sourceTimeCoeffs
$scalarCodedSourceCoeffs;
I think that the problem is the magnitude in pow4(Ts) therm in the heatsource equation. I have control the Ts value in the log and it seems that it is the h value instead of Temperature value with Ts=h/Cp. In consequense, my heatsource term is too large and the temperature explodes when I run the case. I have try to put pw4(Ts/Cp) to put a temperature value inside the equation the heatsource term is too low. and the temperature of the surface is not increasing at all. If I put the line // fieldNames (T); active, an error occurs. I think that I am not too far the solution but as I don't understand exactly what happened I am not able to write the correct equation. If someone knows how to resolve this, it would be very helpfull for me. Best regards Julien |
January 7, 2021, 08:49 |
julien
Rep Power: 7 |
Finally it works!!
Simply, I need to put W unit for the heatsource. It matches perfectly with other software. |
January 8, 2021, 14:37 |
julien
Rep Power: 7 |
I need to monitor the value of the heatsource term added in the fvOption file. I can see it in log file but for each cells of the patch. It is quite heavy in the log file and not very usable. codeAddSup #{ ... Pout << hSource << endl; } Is there a way to create an independant file with my hSourve values via the controlDict file or from the fvOption file ? Best regards |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
