Running in parallel with a machine that doesn't have OpenFOAM |
September 12, 2013, 13:56 |
Jamal
I am running openfoam simulation in parallel on a machine using 4 out of 12 processors and thats working nice. Now I just get an other server without any openfoam installation on it. Now I want to run the same simulation on two machines (servers) one with openfoam installation and the other one without openfoam installation using 4 processors from each machine.... can i do this or not and if i can, then please let me know.... thanks. |
September 14, 2013, 10:08 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Jamal,
Technically a parallel application can only run if the respective software is somehow provided to all of the machines that will be using it. In addition, you better make sure that both machines are running the same architecture, or at least in the lower common architecture, namely both should run in 64 bit or 32 bit. So, there are two possible solutions:
Bruno
OpenFoam Parallel running | shipman | OpenFOAM Running, Solving & CFD | 3 | August 17, 2013 10:50 |
OpenFOAM doesn't run in parallel | callumso | OpenFOAM Running, Solving & CFD | 0 | July 11, 2013 12:17 |
Problem in Running OpenFoam in Parallel | himanshu28 | OpenFOAM Running, Solving & CFD | 1 | July 11, 2013 09:19 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 05:07 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 15:01 |
