c-d nozzle
Old   September 10, 2013, 06:00
Default c-d nozzle
anshul bansal
anshul bansal is on a distinguished road
i have made my 2D c-d nozzle geometry in gambit and mess it in openFoam by some command. and it is done.
but when i run this with rhoCentralFoam solver, it gives some error.
--> FOAM FATAL IO ERROR:
keyword e is undefined in dictionary "/home/anshu/OpenFOAM/anshu-2.2.1/run/tutorials/compressible/rhoCentralFoam/cd_1/system/fvSolution.solvers"
file: /home/anshu/OpenFOAM/anshu-2.2.1/run/tutorials/compressible/rhoCentralFoam/cd_1/system/fvSolution.solvers from line 22 to line 38.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 608.
FOAM exiting
my intial condion for P is like this
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
inlet
type fixedValue;
value uniform 101325;
outlet
type zeroGradient;
axis
type symmetryPlane;
upperwall
type zeroGradient;
frontAndBackPlanes
type empty;
please confirm that is it ok with these boundary condition??/
anshul bansal is offline   Reply With Quote
Old   September 10, 2013, 06:05
anshul bansal
for high enthalpy flow (around M=6 and temp. 7000K), what numerical scheme i take?
Old   September 11, 2013, 05:15
Artur's Avatar
Artur
Artur will become famous soon enough
For your first problem, you didn't specify how you want to solve for "e" in system/fvSolution.
Have a read through the error message and convince yourself that this is the case, will help you in tracking the error sources in the future.
It should be, for instance, in biconic25-55Run35 tutorial:
    e
        $U;
        relTol          0.1;
Artur is offline   Reply With Quote
Old   September 12, 2013, 04:38
anshul bansal
is my boundary conditions are right?
and what solver should i use?... i use rhoCentralFoam solver(but this is density based solver)
can u suggest some pressure based solver.... and check my boundary condition..
Old   September 12, 2013, 05:15
Artur's Avatar
Artur
I'm afraid I can't help you without knowing what it is that you're trying to calculate exactly so some clarification would definitely help...
Old   September 12, 2013, 05:57
anshul bansal
actually i have a c-d nozzle(bell contour). my project about high enthalpy flow. so ii want to simulate a high enthalpy flow through c-d nozzle.
so i made a c-d nozzle(3-d, take 5degree axisymmetry) from gambit and mesh it in openfoam. i check mesh by checkMesh, it is ok.
problem is going on its running through solver.
i have confusion about it's boundary condition and what solver should i take?
i will send you a paper to ur mail id (please send ur mail id) in which my geometry style is given. u just check it and reply me.
Old   September 12, 2013, 06:22
Artur's Avatar
Artur
I'm afraid I have no idea about high enthalpy flows so hopefully someone more capable in this area will answer your post.
All the best and good luck.
Old   September 12, 2013, 06:35
anshul bansal
now this time i'm work with simple compressible flow. so first i done this, after i go for high enthalpy flow.
so advice me for simple compressible flow with my geometry.
(nd send ur mail id,so i can send my geometry to u)
Old   September 23, 2013, 05:42
anshul bansal
Can any body told me which solver i used for c-d nozzle compressible flow ??
Convergent-Divergent Nozzle with MATLAB Obad Main CFD Forum 8 June 2, 2020 14:10
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 00:25
Sonic flow for exhaust nozzle beanlee999 FLUENT 1 May 10, 2012 14:34
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
