mass fraction of the products in reactingFoam solver
Like Tree1Likes
  • 1 Post By babakflame
Old   October 5, 2013, 03:24
Default mass fraction of the products in reactingFoam solver
sonu
yash.aesi is on a distinguished road
Hello ,
Various thread are there about regarding reactingFoam solver but nobody is replying there so i thought to open new thread .
i am using OF-2.2 and PasR model for my case with reactingFoam solver and at the end i noticed 2 things :
1. The temperature is bit on higher side.
2. The mass fraction of the products (CO2 and H2O ) is nearly double of what
of what should come .
so can anybody have any idea why this is happening ?
Thanks in advance
if needed then i can attach my case files .
Regards ,
Sonu
yash.aesi is offline   Reply With Quote
Old   October 6, 2013, 01:51
Bobby
babakflame is on a distinguished road
Hi sonu
Your question is so wide that I can not put anything here.
First of all what is your case exactly?
What BC are you exerting?
If you are using LES, What is your sub-grid scale? Is it suitable for the case or not?
And So on ...............
My suggestion for you is go further step by step and tell me exactly what are you doing. PLZ don't send anything.
Bobi
babakflame is offline   Reply With Quote
Old   October 6, 2013, 10:43
sonu
greetings Bobi ,
i am using OF- 2.2. , and want to simulate the global single step reaction of methane oxygen combustion using reactingFoam solver which uses PasR combustion model . This is the global one step reaction and other values i had given
CH4+2O2= CO2+2H2O
pre- exponential factor = 5.2e16
beta=0
activation temperature=14906
My BC's are :
 fuel_inlet:
CH4: fixed value /1
O2 : fixed value/ 0
N2 : calculated
U: fixed value
p: zero gradient
k/eps/: value
coflow_inlet:
CH4: fixed value / 0
O2: fixed value / 0.23
N2 :calculated
U: fixed value
p: zero gradient
k/eps/: value
 outlet:
CH4:inlet outlet / 0
O2: zero gradient
N2: zero gradient
 U: zero gradient
p: zero Gradient
k/eps: zero gradient
upper_walls:
CH4: zero Gradient
O2: zero gradient
N2: zero gradient  U: fixed value
p: zero gradient
k/eps: uniform/1
internal field:
CH4: 0
N2: 0.77
O2: 0.23
everything else seems to be ok when i checked results but 2 things paining me that temperature is bit on higher side and the mass fraction of the products are almost double of what should come .
so plz Bobi have a look and point out where i am doing wrong
Thank You
Sonu
Old   October 6, 2013, 12:47
Bobby
Hi sonu
I think PaSR combustion model is typically employed with detailed chemistry (Inherent specifics of this model). If you still demand on employing global step reaction; try FSD combustion model which is developed for global step.
I hope you find my suggestion helpful.
Bobi
Old   October 18, 2013, 13:52
sonu
Thanks Bobi ,
Sori i was busy with some other work. ok i will try .
and one more doubt if u can suggest something about it. i am sending you some snapshot of the temperature contour. there in second pic some waviness started to come in the flow. initially its stable as seen from first pic but suddenly after some time it (waviness) comes into picture . So can you suggest any reasons for this to be happening ??
Thank You ,
Regards ,
sonu
Old   October 19, 2013, 03:36
Bobby
Hi Sonu
This issue (not always a problem) depends on some parameters:
1- maybe your grid is not fine enough to capture some unsteadiness in the flame.
2- some flames exhibit local extinctions that cause waviness structures.
So If you want me to help you better , specify your exact flame , otherwise try to fine your grid (be aware that the grid is more sensitive in cross sections resolution than axial resolution i.e. you must refine your mesh at the jet exit and the bluff body if it exists.) and compare the differences. If no difference exists, then it is local extinction.
Another issue: Why your Temp is so high?
What is your fuel? Nuclear one?
Bobi
yash.aesi likes this.
Old   October 19, 2013, 04:19
sonu
Thanks Bobi for such a explained answer.
i will try with the more fine mesh.
actually this is the same case of methane-oxygen combustion which i tried to solve by using the reactingFoam solver, in which i have the problem with the temperature and mass fraction of the products (as posted in above post ). In which u suggested me to try FSD combustion model which is developed for global step. so i am looking for the reason of that waviness that comes in this case which you explained to me .
Thanks for help
Regards,
sonu
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
Mass Fraction and Mole Fraction don't tie up KieranHegarty FLUENT 1 February 28, 2015 10:22
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
Species Mass Fraction in reactingFOAM Marshak OpenFOAM 1 November 29, 2012 01:31
How to obtain the mass fraction of evaporated diesel spray Mnzki FLUENT 0 June 17, 2012 16:22
