chtMultiRegionSimpleFoam: strange error
Like Tree3Likes
Old   October 9, 2013, 10:22
Default chtMultiRegionSimpleFoam: strange error
Samuele Z
samiam1000 is on a distinguished road
Dear all,
trying to run my chtMultiRegionSimpleFoam simulation, I get this error:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.1-57f3c3617a2d
Exec   : chtMultiRegionSimpleFoam
Date   : Oct 09 2013
Time   : 16:09:54
Host   : "lab-laptop"
PID    : 7471
Case   : /home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCMPacks/steady
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region domain1 for time = 0
Create solid mesh for region domain2 for time = 0
Create solid mesh for region domain3 for time = 0
--> FOAM FATAL IO ERROR:
keyword type is undefined in dictionary ".T"
file: .T from line 49 to line 66.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 402.
FOAM exiting
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCMPacks/steady$
The point is that it does not suggest me which is the corrupted file. Any idea? Is the error supposed to be in the domain3 region? Or domain3 is ok and I have to look in the next ones?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   October 12, 2013, 15:16
Retired Super Moderator
Bruno Santos
Hi Samuele,
Try this:
find . -name ".T"
It will tell you where the files named ".T" are located.
By the way, on Linux, files that start with "." are usually considered as hidden files. To see then, use the "-a" option with "ls" or "ll", for examples:
ls -a
ll -a
ls -la
The two last ones should be the same, because "ll" is an alias (when defined as such), as proved by this command:
alias ll
Best regards,
Bruno
Old   October 14, 2013, 04:04
Samuele Z
I Bruno,
the point is that there was not such a file :-/..
..I've changed the folder case name and not I don't have this error.
But I have this new one:
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCMPacks/steady$ chtMultiRegionSimpleFoam
Date   : Oct 14 2013
Time   : 08:55:57
Host   : "lab-laptop"
PID    : 2667
nProcs : 1
Create time
Create solid mesh for region domain5 for time = 0
Create solid mesh for region packs for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package heRhoThermo<pureMixture<const<hConst<perfectGas<specie>>,sensibleEnthalpy>>>
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4  Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#5  Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#6  Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
 in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
Could you help?
Thanks a lot,
Samuele
gomsy1987 likes this.
Old   October 14, 2013, 06:38
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi Samuel,
the first error is nice - never seen that befor.
The last error "Floating Point exeption" occure if you are dividing by Zero.
Check all your BC and set always the "value uniform X" keyword.
But hmmm ... it seems that you get the error while updating the thermodynamics. Maybe when the constructor is selected.
But first check my first hint.
Your meshes are okay?
Boundary files okay too?
Regards
Tobi
Tobi is offline   Reply With Quote
Old   October 14, 2013, 07:49
Samuele Z
Dear Tobi,
thanks for answering. Well, let me have a look at all the BC. Anyway, I am pretty confident it is ok! As far as the mesh is concerned, it should be alright.
I'll give you a feedback, soon.
Thanks a lot,
Samuele
Old   October 21, 2013, 05:39
Samuele Z
Dear Tobi,
I have checked all the BC and I have done some modifications.
The point is that now I have done a small step ahead, but there still is something wrong:
Date   : Oct 21 2013
Time   : 11:26:34
Host   : "lab-laptop"
PID    : 4069
nProcs : 1
Create time
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
--> Upgrading k to employ run-time selectable wall functions
    Backup original k to k.old
    Writing updated k
--> Upgrading epsilon to employ run-time selectable wall functions
    Backup original epsilon to epsilon.old
    Writing updated epsilon
--> Creating mut to employ run-time selectable wall functions
    Writing new mut
--> Creating alphat to employ run-time selectable wall functions
    Writing new alphat
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
    Adding to ghFluid
    Adding to ghfFluid
--> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/Field.C at line 262
    Reading "/home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCMPacks/steady/0/fluid/p_rgh" from line 18 to line 20
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM Warning :
    Reading "/home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCMPacks/steady/0/fluid/p_rgh.boundaryField.intake" from line 55 to line 20
Selecting radiationModel none
    Adding fvOptions
No finite volume options present
*** Reading solid mesh thermophysical properties for region domain1
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    Adding to radiations
Radiation model not active: radiationProperties not found
    Adding fvOptions
*** Reading solid mesh thermophysical properties for region domain2
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
*** Reading solid mesh thermophysical properties for region domain3
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
*** Reading solid mesh thermophysical properties for region domain5
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3  Foam::tmp<Foam::Field<double> > Foam::fvPatch::patchInternalField<double>(Foam::UList<double> const&) const in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#4  Foam::fvPatchField<double>::patchInternalField() const in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#5  Foam::basicSymmetryFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::symmetryFvPatchField<double>::symmetryFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::symmetryFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#8  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#10  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#11  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#12   at basicThermo.C:0
#13  Foam::basicThermo::lookupOrConstruct(Foam::fvMesh const&, char const*) const in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#14  Foam::basicThermo::basicThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#15  Foam::solidThermo::solidThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libsolidThermo.so"
#16  Foam::heThermo<Foam::solidThermo, Foam::pureMixture<Foam::constIsoSolidTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libsolidThermo.so"
#17  Foam::solidThermo::addfvMeshConstructorToTable<Foam::heSolidThermo<Foam::solidThermo, Foam::pureMixture<Foam::constIsoSolidTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libsolidThermo.so"
#18  Foam::autoPtr<Foam::solidThermo> Foam::basicThermo::New<Foam::solidThermo>(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libsolidThermo.so"
#19  Foam::solidThermo::New(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libsolidThermo.so"
#20
#21  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#22
Segmentation fault (core dumped)
Any idea about this `new' (for me) error?
Old   October 21, 2013, 06:28
Tobi's Avatar
Tobias Holzmann
first of all post the p_rgh file (0/fluid/p_rgh).
And the second error (Segmentation fault) is in your domain5. You have an error there.
Old   October 21, 2013, 06:47
Samuele Z
Thanks Tobi.
Here is my p_rgh file:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p_rgh;
dimensions      [ 1 -1 -2 0 0 0 0 ];
internalField   100000;
boundaryField
    wall-fluid
        type            buoyantPressure;
        value           $internalField;
    back
    empty_1
    empty_2-fluid
        type            symmetryPlane;
    glass
    inlet_main
    intake
        type            fixedValue;
    pcm_surface
    fluid_to_domain5
    fluid_to_domain3
    fluid_to_domain1
    fluid_to_packs
    fluid_to_domain2
and here the domain5 changeLogDict:
|  \\    /   O peration     | Version:  2.1.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      changeDictionaryDict;
dictionaryReplacement
    boundary
        empty_2-packs
            type            symmetryPlane;
            nFaces          1342;
            startFace       47303;
        wall_packs
            type            wall;
            nFaces          705;
            startFace       48645;
        domain5_to_fluid
            type            mappedWall;
            nFaces          3997;
            startFace       49350;
            sampleMode      nearestPatchFace;
            sampleRegion    fluid;
            samplePatch     fluid_to_domain1;
            offsetMode      uniform;
            offset          (0 0 0);
    T
        internalField   uniform 298;
        boundaryField
            empty_2-packs
                type            symmetryPlane;
            wall_packs
                type            zeroGradient;
            domain5_to_fluid
                type            compressible::turbulentTemperatureCoupledBaffleMixed;
                value           uniform 298;
                neighbourFieldName T;
                kappa           solidThermo;
                kappaName       none;
    p
        internalField   uniform 100000;
        boundaryField
            empty_2-packs
                type            symmetryPlane;
            wall_packs
                type            calculated;
                value           uniform 0;
            domain5_to_fluid
                type            calculated;
                value           uniform 0;
Thanks for answering and helping,
Samuele
Old   October 21, 2013, 09:26
Samuele Z
Hi Tobi,
following your advice, I solved an error, but I now get this message:
Attempt to cast type calculated to type compressible::turbulentTemperatureCoupledBaffleMixed
However, I think that my BC are properly set. Where may the error be, according to you?
Thanks a lot,
Samuele
Old   October 21, 2013, 11:02
Tobi's Avatar
Tobias Holzmann
Hi
       domain5_to_fluid
            type            mappedWall;
            nFaces          3997;
            startFace       49350;
            sampleRegion    fluid;
            samplePatch     fluid_to_domain1;  // should be fluid_to_domain5
            offsetMode      uniform;
            offset          (0 0 0);
The other error... can you give me more information?
Old   October 21, 2013, 11:12
Samuele Z
Yeah: it's right.
About the `new error', here is the complete message:
Date   : Oct 21 2013
Time   : 16:10:36
Host   : "lab-laptop"
PID    : 2401
nProcs : 1
Create time
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
    Adding to ghFluid
    Adding to ghfFluid
--> FOAM Warning :
--> FOAM Warning :
    Adding fvOptions
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
*** Reading solid mesh thermophysical properties for region packs
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
    Adding fvOptions
Time = 1
Solving for fluid region fluid
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.00545361, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.018735, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 0.00880018, No Iterations 1
--> FOAM FATAL ERROR:
Attempt to cast type zeroGradient to type compressible::turbulentTemperatureCoupledBaffleMixed
    From function refCast<To>(From&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
#1  Foam::error::abort() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::compressible::turbulentTemperatureCoupledBaffleMixedFvPatchScalarField::updateCoeffs() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#3  Foam::mixedFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::mixedEnergyFvPatchScalarField::updateCoeffs() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#5  Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
Aborted (core dumped)
Old   October 21, 2013, 12:02
Tobi's Avatar
Tobias Holzmann
T file of fluid please and the boundary file of your fluid domain.
Old   October 23, 2013, 02:56
Samuele Z
Tobi,
pardon for the late answer. I was out of office and I did not have the case with me. Sorry,
Anyway, the file that you want is here:
    T
        boundaryField
            wall-fluid
                type            zeroGradient;
                value           uniform 273;
            back
                type            zeroGradient;
//                type            fixedValue;
                value           uniform 273;
            empty_1
                type            zeroGradient;
                value           uniform 273;
            empty_2-fluid
                type            symmetryPlane;
            glass
                type            fixedValue;
                value           uniform 298;
            inlet_main
                type            fixedValue;
                value           uniform 273;
            intake
                type            zeroGradient;
                value           uniform 273;
            pcm_surface
                type            fixedValue;
                value           uniform 275;
            fluid_to_domain5
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 278;
            fluid_to_domain3
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 278;
            fluid_to_domain1
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 278;
            fluid_to_packs
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 278;
            fluid_to_domain2
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 278;
Is there something strange?
Old   October 23, 2013, 04:37
Samuele Z
Tobi,
I have solved that problem, changing the BC. But I still have troubles: now I get this message:
Solving for solid region domain1
    gradientInternalCoeffs cannot be called for a calculatedFvPatchField
    on patch domain1_to_fluid of field h in file "/home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCMPacks/steady/0/domain1/h"
    You are probably trying to solve for a field with a default boundary condition.
    From function calculatedFvPatchField<Type>::gradientInternalCoeffs() const
    in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 199.
FOAM exiting
The point is that I don't have any h file, anywhere.
Any idea about this?
Old   October 23, 2013, 07:03
Tobi's Avatar
Tobias Holzmann
the T-file Looks good.
The Problem in the cht solver is always that the Domains are related to each other and the Problem could be in both. I worked a Long time with the cht but at the Moment I am not working anymore with it.
Therefor I am getting rusty in the error Messages
Is it possible to upload you 0 Folder and the constant Folder, best way would be the whole case.
Maybe its not possible for you (due to secret) it would be very good to have the 0 Folder and the constant/***/polyMesh/boundary files to have a look at the whole case. It would be the best way to give you a correct answer.
Otherwise you should always get more Information
So if you solving "domain1_to_fluid" it is interessting to have the related files of both Domains.
For your Problem it could be possible that you use "fluidThermo" in the T file for your solid Domain. there should be "solidThermo".
Regards Tobi
Old   October 23, 2013, 08:20
Samuele Z
I can share the case with you via Skype. I have tried to contact you there.
If you are online, please let me know. Otherwise, please write me at samuele.zampini@polimi.com and I'll send you tha case.
Thank you very much,
Samuele
Old   October 23, 2013, 08:39
Tobi's Avatar
Tobias Holzmann
Hi Samuel,
i am online today evening (in 2 hours).
Otherwise you can send me the case Tobias.Holzmann@Holzmann-cfd.de
Regards
Tobi
Old   October 23, 2013, 11:10
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Originally Posted by samiam1000 View Post
Tobi,
FOAM exiting
i experienced such a problem before, already today. i found that my mistake was in changeDirectoryDict where i wrongly wrote than name of interface patch, i simply change uppercase letter to lowercase. that's it.
i hope it will be helpful for you.
samiam1000 likes this.
Ahmed Khattab is offline   Reply With Quote
Old   October 23, 2013, 11:24
Samuele Z
I'm pretty sure about the patch names, but I'll check them again!
Thanks!
Old   October 23, 2013, 13:09
Tobi's Avatar
Tobias Holzmann
1. your changeDict has a wrong entry like ahmed mentioned in your domain2
            domain2_to_fluid
                type            mappedWall;
                nFaces          3997;
                startFace       49350;
                sampleRegion    fluid;
                samplePatch     fluid_to_domain1;  //domain2
                offsetMode      uniform;
                offset          (0 0 0);
2. wrong schemes and solution for your solids
3. wrong changeDict in domain1
    T
        boundaryField
                    empty_2-packs
                        type            symmetryPlane;
                    wall_packs
                        type            zeroGradient        // forget ";"
                    domain1_to_fluid
                                value           uniform 298;
                                kappa           solidThermo;
                                kappaName       none;
4. after changeDict on domain2 there are still one error in your "0/domain2/T" file:
   empty_2-packs
        type            symmetryPlane;
    wall_packs
        type            zeroGradient
    domain1_to_fluid
        value           uniform 298;
        kappa           solidThermo;
        kappaName       none;
    domain1_to_fluid                      // wrong - not needed
        type            calculated;
        value           uniform 0;
        kappa           solidThermo;
        kappaName       none;
After the changes you will get the following output:
Time = 1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.0024031, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.0099621, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 0.0132661, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1, Final residual = 0.0987243, No Iterations 4
Min/max T:269.145 301.75
DICPCG:  Solving for p_rgh, Initial residual = 0.999968, Final residual = 0.0094627, No Iterations 19
time step continuity errors : sum local = 22257.7, global = -0.00312494, cumulative = -0.00312494
Min/max rho:0.001 1.29413
DICPCG:  Solving for h, Initial residual = 1, Final residual = 0.0184498, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 297.999 max(T) [0 0 0 1 0 0 0] 298.001
Solving for solid region domain2
DICPCG:  Solving for h, Initial residual = 1, Final residual = 0.0187101, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 276.999 max(T) [0 0 0 1 0 0 0] 277.003
Solving for solid region domain3
DICPCG:  Solving for h, Initial residual = 1, Final residual = 0.0906404, No Iterations 1
Solving for solid region domain5
DICPCG:  Solving for h, Initial residual = 1, Final residual = 0.0785481, No Iterations 1
Min/max T:min(T) [0 0 0 1 0 0 0] 297.999 max(T) [0 0 0 1 0 0 0] 298.002
Solving for solid region packs
DICPCG:  Solving for h, Initial residual = 1, Final residual = 0.0262329, No Iterations 2
ExecutionTime = 5.9 s  ClockTime = 6 s
- the second iteration is bad but I switched off the turbulence modelling and do not check the BC.
Have fun and good luck.
Regard
Tobi
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
user defined function cfduser CFX 0 April 29, 2006 10:58
