mpirun interFoam very stable --> then blows up
Old   February 22, 2013, 02:49
Angry mpirun interFoam very stable --> then blows up
Ziad
ghadab is on a distinguished road
Dear friends,
i am working with the interFoam solver and running the simulation on 24 processors. After two days of calculation one of the processors blows up. If i read the log before the error, i see that the simulation was stable (maxco, residuals, time step, ...). I copied for you the last lines of the logfile.
MULES: Solving for alpha1
Phase-1 volume fraction = 0.93216176 Min(alpha1) = -5.5510116e-20 Max(alpha1) = 1.0000333
Phase-1 volume fraction = 0.93216177 Min(alpha1) = -1.5739172e-19 Max(alpha1) = 1.0000347
Phase-1 volume fraction = 0.93216178 Min(alpha1) = -2.0048211e-19 Max(alpha1) = 1.0000359
Phase-1 volume fraction = 0.93216179 Min(alpha1) = -1.6316185e-19 Max(alpha1) = 1.000037
GAMG: Solving for p_rgh, Initial residual = 0.00055114557, Final residual = 7.5653985e-06, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 8.8321274e-05, Final residual = 6.1051387e-06, No Iterations 1
time step continuity errors : sum local = 4.5327434e-10, global = -5.4431254e-12, cumulative = -0.00078028933
GAMG: Solving for p_rgh, Initial residual = 0.00016425054, Final residual = 4.5803235e-06, No Iterations 2
GAMGPCG: Solving for p_rgh, Initial residual = 5.0422281e-05, Final residual = 1.520426e-06, No Iterations 1
time step continuity errors : sum local = 1.1287501e-10, global = 1.3621927e-13, cumulative = -0.00078028933
DILUPBiCG: Solving for k, Initial residual = 0.00023313691, Final residual = 8.5579005e-09, No Iterations 3
bounding k, min: -1.2733491e-05 max: 4.7929403 average: 0.042688034
ExecutionTime = 232572.69 s ClockTime = 233069 s
Courant Number mean: 0.011293328 max: 0.50499715
Interface Courant Number mean: 0.00034175293 max: 0.13210925
deltaT = 8.5249158e-06
Time = 1.25438208
Phase-1 volume fraction = 0.9321618 Min(alpha1) = -1.7904223e-19 Max(alpha1) = 1.0000387
Phase-1 volume fraction = 0.93216181 Min(alpha1) = -7.3661288e-20 Max(alpha1) = 1.0000406
Phase-1 volume fraction = 0.93216183 Min(alpha1) = -3.8216149e-20 Max(alpha1) = 1.0000422
Phase-1 volume fraction = 0.93216184 Min(alpha1) = -8.0706645e-20 Max(alpha1) = 1.0000437
GAMG: Solving for p_rgh, Initial residual = 0.00072098495, Final residual = 8.618023e-06, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 0.00010279397, Final residual = 6.9378374e-06, No Iterations 1
time step continuity errors : sum local = 5.0463324e-10, global = 1.4211672e-12, cumulative = -0.00078028932
GAMG: Solving for p_rgh, Initial residual = 0.00016345643, Final residual = 4.7007859e-06, No Iterations 2
GAMGPCG: Solving for p_rgh, Initial residual = 5.0320654e-05, Final residual = 1.5890004e-06, No Iterations 1
time step continuity errors : sum local = 1.1557738e-10, global = -6.230831e-13, cumulative = -0.00078028933
DILUPBiCG: Solving for k, Initial residual = 0.00023066785, Final residual = 6.6803586e-09, No Iterations 3
bounding k, min: -9.637777e-05 max: 4.9497763 average: 0.042689423
ExecutionTime = 232574.05 s ClockTime = 233071 s
Courant Number mean: 0.011173537 max: 0.50453059
Interface Courant Number mean: 0.00033831272 max: 0.13069177
deltaT = 8.4479993e-06
Time = 1.25439053
Phase-1 volume fraction = 0.93216185 Min(alpha1) = -1.5646013e-19 Max(alpha1) = 1.0000451
Phase-1 volume fraction = 0.93216186 Min(alpha1) = -8.945875e-20 Max(alpha1) = 1.0000463
Phase-1 volume fraction = 0.93216187 Min(alpha1) = -2.122793e-19 Max(alpha1) = 1.0000474
Phase-1 volume fraction = 0.93216189 Min(alpha1) = -1.8830937e-19 Max(alpha1) = 1.0000485
GAMG: Solving for p_rgh, Initial residual = 0.00067100595, Final residual = 8.5266915e-06, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 9.7152886e-05, Final residual = 6.6805452e-06, No Iterations 1
time step continuity errors : sum local = 4.7779724e-10, global = -1.6421516e-12, cumulative = -0.00078028933
GAMG: Solving for p_rgh, Initial residual = 0.00016094755, Final residual = 4.6225229e-06, No Iterations 2
GAMGPCG: Solving for p_rgh, Initial residual = 4.9303045e-05, Final residual = 1.5754646e-06, No Iterations 1
time step continuity errors : sum local = 1.1267799e-10, global = 2.7460826e-13, cumulative = -0.00078028933
DILUPBiCG: Solving for k, Initial residual = 0.00022857712, Final residual = 5.4361084e-09, No Iterations 3
bounding k, min: -0.00070291813 max: 5.1064455 average: 0.042690956
ExecutionTime = 232575.42 s ClockTime = 233072 s
Courant Number mean: 0.011072711 max: 0.50475466
Interface Courant Number mean: 0.00033544306 max: 0.12948992
deltaT = 8.3598681e-06
Time = 1.25439889
Phase-1 volume fraction = 0.9321619 Min(alpha1) = -7.8526875e-20 Max(alpha1) = 1.0000496
Phase-1 volume fraction = 0.93216191 Min(alpha1) = -1.0447194e-19 Max(alpha1) = 1.0000507
Phase-1 volume fraction = 0.93216192 Min(alpha1) = -8.0890711e-20 Max(alpha1) = 1.0000516
Phase-1 volume fraction = 0.93216193 Min(alpha1) = -2.1416833e-19 Max(alpha1) = 1.0000525
GAMG: Solving for p_rgh, Initial residual = 0.00067214463, Final residual = 8.3396353e-06, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 9.3977145e-05, Final residual = 6.43286e-06, No Iterations 1
time step continuity errors : sum local = 4.5116681e-10, global = -1.6635553e-12, cumulative = -0.00078028933
GAMG: Solving for p_rgh, Initial residual = 0.00015785756, Final residual = 4.5155882e-06, No Iterations 2
GAMGPCG: Solving for p_rgh, Initial residual = 4.8203437e-05, Final residual = 1.5168408e-06, No Iterations 1
time step continuity errors : sum local = 1.0638073e-10, global = 2.1630499e-13, cumulative = -0.00078028933
DILUPBiCG: Solving for k, Initial residual = 0.00022623408, Final residual = 3.8751548e-09, No Iterations 3
bounding k, min: -0.018329866 max: 5.2509637 average: 0.042692732
ExecutionTime = 232576.78 s ClockTime = 233073 s
Courant Number mean: 0.010957187 max: 0.50412939
Interface Courant Number mean: 0.00033184779 max: 0.12811218
deltaT = 8.2856681e-06
Time = 1.25440717
Phase-1 volume fraction = 0.93216194 Min(alpha1) = -6.9553818e-20 Max(alpha1) = 1.0000535
Phase-1 volume fraction = 0.93216195 Min(alpha1) = -1.49288e-19 Max(alpha1) = 1.0000544
Phase-1 volume fraction = 0.93216197 Min(alpha1) = -8.8329747e-20 Max(alpha1) = 1.0000552
Phase-1 volume fraction = 0.93216198 Min(alpha1) = -1.8334624e-19 Max(alpha1) = 1.000056
GAMG: Solving for p_rgh, Initial residual = 0.00062626096, Final residual = 8.1036593e-06, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 8.8361519e-05, Final residual = 6.1779555e-06, No Iterations 1
time step continuity errors : sum local = 4.2607103e-10, global = -5.6739447e-13, cumulative = -0.00078028933
GAMG: Solving for p_rgh, Initial residual = 0.00015557742, Final residual = 4.3762882e-06, No Iterations 2
GAMGPCG: Solving for p_rgh, Initial residual = 4.7961358e-05, Final residual = 1.5262668e-06, No Iterations 1
time step continuity errors : sum local = 1.0526006e-10, global = -2.1962042e-13, cumulative = -0.00078028933
[2] #0 Foam::error: printStack(Foam::Ostream&)[7] #0 Foam::error: printStack(Foam::Ostream&)[8] #0 Foam::error: printStack(Foam::Ostream&)[4] #0 Foam::error: printStack(Foam::Ostream&)[5] #0 Foam::error: printStack(Foam::Ostream&)[6] #0 [9] #0 Foam::error: printStack(Foam::Ostream&)[10] #0 Foam::error: printStack(Foam::Ostream&)[11] #0 Foam::error: printStack(Foam::Ostream&)[1] #0 Foam::error: printStack(Foam::Ostream&)[3] #0 Foam::error: printStack(Foam::Ostream&)Foam::error: printStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&)[14] #0 Foam::error: printStack(Foam::Ostream&)[17] #0 Foam::error: printStack(Foam::Ostream&)[19] #0 Foam::error: printStack(Foam::Ostream&)[20] #0 Foam::error: printStack(Foam::Ostream&)[12] #0 Foam::error: printStack(Foam::Ostream&)[13] #0 Foam::error: printStack(Foam::Ostream&)[15] #0 Foam::error: printStack(Foam::Ostream&)[16] #0 Foam::error: printStack(Foam::Ostream&)[18] #0 Foam::error: printStack(Foam::Ostream&)[21] #0 Foam::error: printStack(Foam::Ostream&)[22] #[23] #00 Foam::error: printStack(Foam::Ostream&)Foam::error: printStack(Foam::Ostream&)--------------------------------------------------------------------------
An MPI process has executed an operation involving a call to the
"fork()" system call to create a child process. Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your MPI job may hang, crash, or produce silent
data corruption. The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
I hope you can help me and i will be able to give you all data you need like system/ 0/ and constant/ folders.
Best Regards
Ziad
ghadab is offline   Reply With Quote
Old   February 22, 2013, 03:43
Bernhard
Bernhard is on a distinguished road
I have been experiencing similar error-messages recently. Maybe you can look in this thread for hints: http://www.cfd-online.com/Forums/ope...ork-error.html
Bernhard is offline   Reply With Quote
Old   February 22, 2013, 04:07
Ziad
Dear Bernhard,
thank you for your reply. Actually i am working on cluster and i do not have any idea if other applications run parallel with my simulation ( but i do not think so!). I started the same simulation 2 times, where in the second one i changed the MaxCo from 0.8 to 0.5. Both blow up.
Old   October 27, 2013, 10:34
Albert Tong
tfuwa is on a distinguished road
Originally Posted by ghadab View Post
Dear Bernhard,
Hi Ziad,
Just wondering if you have solved this. I am experiencing the same problem. The simulation just blows up at a time long after the it is stable. Can you please share your solution? Many thanks.
Kind regards,
Albert
tfuwa is offline   Reply With Quote
interfoam, mpirun
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
under what circumstances would interFoam have alpha > 1? yanxiang OpenFOAM Running, Solving & CFD 1 July 15, 2013 16:29
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 02:09
interFoam case blows up jrrygg OpenFOAM Running, Solving & CFD 8 November 14, 2012 03:16
