modified interPhasechangeFoam base Temp
Old   October 12, 2013, 08:24
Default modified interPhasechangeFoam base Temp
Mohammad Bahreini
mecman is on a distinguished road
Hello foamers
I have managed to implement the interPhaseChangeFoam solver according to the project done by Martin Andersen [http://www.google.com/url?sa=t&rct=j...3899372,d.cGE]. I have also modified the solver to take the account of variable diffusion coefficient [DT ] based on the volume fraction of both phases. I have successfully compiled the solver and managed to get reasonable results on tutorial case. However, when I try to use this solver on my own case, I get completely wrong results. [A 2D case(pipe) that in bottom temperature 5 k more than saturation temperature and All of the wall velocity and pressure is zero gradient ]. After just a few time steps, temperature goes very high (higher than 200000 k) in just a few cells at the corner of the geometry, as I think it’s the problem of singularity. Meanwhile, water phase evaporates quickly in a very short period of time. I have tried different mesh size and boundary condition and the problem is still there. I have attached the solver and my test case here, so you guys can kindly help me get through this issue.
Regards and thank you in advance
link upload:
http://www.uplooder.net/cgi-bin/dl.c...963f28b866e1c5
http://www.uplooder.net/cgi-bin/dl.c...03cc17ab200e16
mecman is offline   Reply With Quote
Old   October 12, 2013, 08:32
Default I try a simple case
Mohammad Bahreini
Hi Foarmers
I try my solver in simple test.(Stephan Problem) but I see the water phase evaporates quickly in a very short period of time (low 0.005 s). I dont know what happen..I think dont understand Property this Solver(interPhasechangeFoam) and I cant use this solver for this cases.
stephan Problem:
http://www.uplooder.net/cgi-bin/dl.c...b7e5e7c33e013e
Old   October 17, 2013, 16:37
Default anybody can Help me??
Mohammad Bahreini
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 11:03
interFoam & decomposition method: scotch MacGyver OpenFOAM Running, Solving & CFD 2 May 23, 2012 07:00
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
