Volume of fluid contained in a cell
Old   November 5, 2013, 06:28
Default Volume of fluid contained in a cell
Sujatha is on a distinguished road
Hi all
Can anybody please let me know how to find the volume of fluid contained in a cell or domain as a whole.
Am working in interFoam and want to find the volume of fluid in the domain at different time.
Any hint will be a privilege.
Thanks in advance
Regards
Sujatha
Sujatha is offline   Reply With Quote
Old   November 5, 2013, 08:55
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Sujatha,
output of interFoam gives you "Phase-1 volume fraction". This value multplied by the total volume of the domain (e.g. from checkMesh) gives the volume of phase-1
Hope this helps,
Jan
JNSN is offline   Reply With Quote
Old   November 5, 2013, 11:46
Thank You , sir,JNSN for your quick and worthy reply.
But since I am a newbie to CFD and OpenFOAM , am still confused. Will the output log file be giving the volume fraction of a single cell? And in my case of "damBreak" initially all the cells won't have liquid phase but only a column of water at one end of the domain.
Also, volume fraction of phase1 remains almost same value for me through out ma simulation.
I will be grateful if you could kindly go through the above issues. Please excuse if these are a sort of blunders, as it's due to my ignorance.
Thanks again
Regards
Sujatha
Old   November 5, 2013, 12:20
JNSN's Avatar
Jan
No, the solver output gives the volume fraction in the whole domain. If you are interested in the volume fraction in a single cell, the easiest way may is with a probe
functions
    probe
        type probes;
        probeLocations ((x y z));
        fields (alpha1);
This gives you the volume fraction at a specified points.
Best regards,
Jan
Old   November 5, 2013, 22:19
This helps sir, JNSN.
Thanks a million.
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 11, 2012 23:13
Negative cell volume problem in-cylinder ziani.lotfi FLUENT 0 April 11, 2012 07:54
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
