Is it possible to solve the flow field with different turbulence models on regions |
November 16, 2013, 23:57 |
Zifei Yin
Let's say, I need part of the mesh solving by LES and part of the mesh solving by DES or RANS. The hole domain is a channel, the upstream should be solved by a LES solver and downstream should be solved by DES/RANS solver.
Is it possible to do that in OpenFOAM? How? Thanks |
November 18, 2013, 15:18 |
Coupling DNS and RANS
Dear Zifei,
interesting question! To my knowledge it will be quite challenging to couple these two different ways of solution. Probably your best chances are either with one of the multiRegion-solvers (to my knowledge a fluid-fluid-interface is not yet implemented in that one) or with the fvMeshSubset-functionality. Unfortunately I am not deep enough in the development right now to know if something like that is implemented so far. Good luck with finding the capabilities in OpenFoam! ;-) Regards, Bernhard |
November 19, 2013, 02:24 |
Bernhard
Rep Power: 21 |
You might want to look at LEMOS
http://www.lemos.uni-rostock.de/en/d.../cfd-software/ |
Basic explanation of turbulence models | Ashh | CFX | 2 | October 10, 2013 05:12 |
Setting up Case for different turbulence models with buoyancy-driven flow | MisterX | OpenFOAM Pre-Processing | 1 | November 19, 2012 05:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 03:03 |
