Discrepancy in Pressure Driven Flow Behaviour in 211 vs 221 |
September 24, 2013, 12:15 |
Discrepancy in Pressure Driven Flow Behaviour in 211 vs 221, solver: rhoCentralFoam
Rep Power: 13 |
Not sure if this should be posted under Bugs, but I'm hoping someone can verify/clarify an issue I'm having when transitioning from OF 211 to 221.
I spent some time investigating k-Omega SST wall function behaviour over a flat plate using the rhoCentralFoam solver and pressure driven flow. I wanted to ensure that the k-Omega SST wall functions would follow closely the standard log-law for a mesh with yPlusRAS of roughly 75 in the area of interest. However, in the process of investigating this, I discovered a more fundamental issue that hopefully someone might be able to clarify. The case was set up as shown in the image below. The inlet uses totalPressure and totalTemperature boundary conditions, and the outlet is fixed pressure with all else being zeroGradient. The case was set up to approximate Ma = 0.8 subsonic, compressible flow. flatplate_setup.jpg The mesh was created in ICEM and converted for use in OF using fluent3DMeshToFoam. Pressure driven flow was chosen to match as closely as possible the simulation setup in ANSYS, as we sought to compare results of both utilities. A number of issues came up, not least of which being that the wall shear stress calculated using the wallShearStress utility was significantly impacted by the chosen fvSchemes (mainly, the Interpolation Schemes). However, more importantly to this post, when plotting the inlet pressure/velocity distributions there is a significant difference between the versions tested of OpenFOAM, all else being equal between the cases. In version 2.2.1 inlet pressure and velocity was significantly impacted by changes to the Gamma differencing value specified in the interpolationSchemes of the fvSolution dictionary. The plots below illustrate the differences in each of the tested cases, for pressure and velocity plotted over the inlet. Summarised, in version 2.1.1 the sensitivity to changes in the gamma differencing (or vanLeer) was negligible, while for 2.2.1 the sensitivity was severe. For reference, Fluent yielded an inlet P = 101683 Pa, U = 273 m/s. OpenFOAM v2.1.1: U = 274 m/s (Gamma 1.0) U = 274 m/s (Gamma 0.5) U = 274 m/s (vanLeer) P = 101665 Pa (Gamma 1.0) P = 101589 Pa (Gamma 0.5) P = 101583 Pa (vanLeer) OpenFOAM v2.2.1: U = 316 m/s (Gamma 1.0) U = 292 m/s (Gamma 0.5) U = 292 m/s (vanLeer) P = 102845 Pa (Gamma 1.0) P = 101771 Pa (Gamma 0.5) P = 101737 Pa (vanLeer) Inlet Pressure: inlet_P.jpg Inlet Velocity: inlet_U.jpg As is obvious from the plots, the pressure and velocity change at the inlet is negligible in 2.1.1 but is quite drastic in 2.2.1. The totalPressure boundary condition has not changed - the only change I can find is in the rhoCentralFoam energy equation: two previously "corrective" terms have been removed (appropriately). So why is there such a sensitivity suddenly to the interpolationSchemes? v2.1.1 matches very well with Fluent, but v.2.2.1 is all over the place. Any ideas? Last edited by cdm; September 26, 2013 at 19:23. Reason: Corrected title to add solver used; fixed typo |
October 28, 2013, 18:03 |
Rep Power: 13 |
I hate to dredge up old posts, but I was hoping someone may have some insight into the above issue.
October 31, 2013, 15:40 |
Rep Power: 13 |
Hello cdm,
have you tried to re-insert the two terms you mentioned into the solver? So one could see, if these terms are the source for the differences? I used rhoCentralFoam for validation as well. I always got better results with the vanLeer scheme compared to results with the gamma scheme. I think, the vanLeer scheme is also used in the paper, where rhoCentralFoam was presented. Regards, maHein |
November 1, 2013, 14:06 |
Rep Power: 13 |
Hi maHein,
Thanks for your reply. While I haven't added the two terms back into the energy equation, they should not be there anyway, so if their removal is what is causing this discrepancy, there is a worse underlying issue in rhoCentralFoam. That said, I haven't gotten into the world of compiling my own solvers nor have I had time to learn how to do so. Which version of OF did you use for your validations with rhoCentralFoam? Did you encounter any discrepancies? |
December 10, 2013, 16:39 |
Rep Power: 13 |
December 17, 2013, 07:48 |
#6 | |
caduqued
Rep Power: 17 |
Have you been able to check if this change corrects your initial case? Should we now assume that the latest version of OF correctly validates, for instance, in your case? Regards, caduqued |
rhocentralfoam, totalpressure |
internal flow BCs: pressure driven versus velocity driven | mihaipruna | OpenFOAM Running, Solving & CFD | 22 | March 6, 2014 10:06 |
Pressure driven flow in vertical pipe | Hale | OpenFOAM Pre-Processing | 6 | September 13, 2013 08:16 |
reference pressure and compressible flow | bingo10 | CFX | 0 | September 11, 2013 07:32 |
pressure BC in buoynacy driven flow | Sasha | FLUENT | 3 | October 11, 2006 10:08 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
