foamCalc: Fatal io error calculating divergence of velocity field |
February 4, 2014, 10:20 |
Rep Power: 12 |
I have an error I don't understand when I try and calculate the divergence of a velocity field. I'm using openFoam 2.2.2 and am using the planeWall2D case fond here: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D I'm trying to calculate the divergence of the velocity field using foamCalc. The command I use is Code:
> foamCalc div U -region bottomAir Code:
div(U) Gauss linear Code:
div(U) Gauss cubic Code:
Time = 50000 Reading U Calculating divU --> FOAM warning : --> FOAM FATAL IO ERROR: attempt to read beyond EOF file: ....../planeWall2D/system/bottomAir/fvSchemes.divSchemes.div(U) at line 39 Regards, P.S. I copied the code an output by hand so there might be some typos in there. They are not the cause of the error I see, but caused by my poor typing skills. |
divergence, foamcalc |
Editing chtMultiRegionFoam to not solve velocity field | tH3f0rC3 | OpenFOAM | 18 | January 24, 2020 16:39 |
[OpenFOAM] velocity Scalar field for paraview contour | Jens123 | ParaView | 0 | November 16, 2013 07:15 |
velocity of massless particles and velocity of flow field in same coordinate | payam_IUST | FLUENT | 0 | October 18, 2009 23:24 |
Divergence in Velocity Field | vidyaraja | FLUENT | 0 | May 6, 2009 08:35 |
Pressure from velocity field | Svante Hellzén | Main CFD Forum | 5 | November 30, 1999 18:20 |
