June 24, 2015, 21:00 |
ChtMultiRegionFoam heat flux
Ganesh Ravi shanker
I am new to OpenFoam and with the help of the openfoam user guides I am working on heat conduction between two solids. I am using ChtMultiRegionFoam solver and compressible::turbulentTemperatureCoupledBaffleMix ed boundary condition for the interface between the solids. And this is the scheme I am using laplacianSchemes { laplacian(alpha,h) Gauss linear limited 0.333; } Successfully I am able to get the output temperature T, but I would like to calculate the heat flux on the solids. Is there any way to do so? Can anyone help me on this ? |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Wall Heat Flux & Temperature | Greg Perkins | FLUENT | 10 | November 20, 2015 09:32 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Negative Heat Flux | shashank312 | FLUENT | 3 | December 9, 2011 17:00 |
