December 18, 2013, 08:39 |
switching from RAS to LES
Rep Power: 12 |
Hi Foamers,
I successfully ran a RANS simulation of industrial fan with all wall BCs, pimpleDyMFoam solver and spallart-almaras RAS model. I got results upto some time, I would like to continue that simulation with LES instead of RAS, what are the options how I need to refine the mesh. (one parameter is way off the experimental value) For instance if I am using one equation eddy model, how to accommodate nuSgs for the solution with RAS? quick help would be appreciated |
les, openfoam |
Switching on LES in 2D mode of fluent | Josef Dubsky | FLUENT | 27 | March 16, 2016 13:49 |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
RAS or LES for rhoCentralFoam | ehsanesl | OpenFOAM Running, Solving & CFD | 2 | September 2, 2013 12:26 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
