June 20, 2013, 08:54 |
buoyantPimpleFoam and DDES
Vincent RIVOLA
Rep Power: 18 |
Dear all,
I would like to try to run buoyantPimpleFoam using SpalartAllmarasDDES. I am using OpenFOAM-2.2.0 and when running the program I get the following error message: Selecting LES turbulence model SpalartAllmarasIDDES --> FOAM FATAL ERROR: Unknown LESModel type SpalartAllmarasIDDES Valid LESModel types: 6 ( DeardorffDiffStress Smagorinsky SpalartAllmaras homogeneousDynOneEqEddy lowReOneEqEddy oneEqEddy ) Can someone explain me why the model is not available in my case? |
June 21, 2013, 02:49 |
Vincent RIVOLA
Rep Power: 18 |
no idea?
could the problem be coming from the fact that SpalartAllmarasDDES would be implemented for incompressible solvers and not for compressible ones? |
October 6, 2013, 16:01 |
Mohsen KiaMansouri
Rep Power: 16 |
Yeah you are right.
SpalartAllmarasDDES is not available for compressible flows: LES it is implemented only for incompressible flows in OpenFOAM: LES
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
December 22, 2013, 02:36 |
Peter
Rep Power: 14 |
Hi, Mohsen!
The buoyantPimpleFoam solver can deal with incompressible flows according to this file: http://static.squarespace.com/static...ormat=original at least for version 1.7.x of OpenFOAM. I wonder why it is limited to the ”compressible” turbulence models. You have any ideas? Thanks. palmerlee |
