January 14, 2014, 22:01 |
Add ignition but combustion does not occur
Rep Power: 12 |
Hi, I am trying to do some simulation about the combustion of isooctane. I use reactingFoam which includes chemkin of isooctane. For the ignition, I add fvOptions in the system. The ignition during is 0.001s. However, the maximum temperature goes up during the ignition and goes down very quickly after the ignition which means no combustion occurs. So, could anyone gives me some advice how to deal with this problem. Thanks in advance.
January 18, 2014, 07:52 |
Bobby
Rep Power: 15 |
Greetings zhuguangfei
For having combustion, first you should clarify your combustion model in O.F. If you are using PaSR model (I guess), Raise the temperature of the fuel stream upper than auto-ignition temperature, after starting the combustion, change it to normal temperature in the boundary condition of your T file. There is no need to use ignition. Regards Bobi |
January 18, 2014, 14:16 |
#3 | |
Rep Power: 12 |
First, thanks for your kind reply. My initial temperature is 330 K and the boundary condition is wall boundary. That means the mixture is homogeneous. Then I add an ignition (fvOptions). You are right that I choose PaSR combustion model. So,I just guess maybe the ignition duration is too small which means the diffusion overcomes the injection energy leading to extinguish. By the way, could you tell me the meaning of injectionRateSuSp { h (10, 0) } in the fvOptions? Thanks so much. Best Regards, Colin |
January 19, 2014, 01:43 |
Bobby
Rep Power: 15 |
Unfortunately, I don't use ignition for having combustion with PaSR combustion model. I think that is a source term for enthalpy in enthalpy equation that causes a sudden increase in temperature. I think my suggestion was not enough transparent. After starting injecting your fuel stream with a Temp more than 2000 K , you will have combustion automatically. After passing a while, save your result and in the temperature file change your fuel stream temperature to 300 K. This is the way that we start combustion in PaSR model without using ignition. Regards Bobi Last edited by babakflame; January 19, 2014 at 09:35. |
Ignition timing for diesel combustion | Ankur | Siemens | 5 | March 15, 2008 20:18 |
Premixed combustion in Spark Ignition engine | kevin | FLUENT | 1 | June 23, 2006 02:59 |
Ignition and combustion | Mai | Siemens | 7 | May 10, 2006 09:59 |
Spontaneous combustion or auto ignition in FLUENT | Seba | FLUENT | 3 | December 8, 2005 23:06 |
Need Similar Combustion Tutorial as my model | Arnab | Siemens | 0 | May 24, 2005 18:23 |
