bubbleFoam tutorial case with turbulence
Old   January 21, 2014, 10:39
Default bubbleFoam tutorial case with turbulence
setzberg is on a distinguished road
I copied the tutorial case for the bubbleFoam solver. I want to do a simulation with turbulence. I use OpenFOAM 2.1.1
Therefore I did the following changes in constant/RASProperties
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
Additionally I added the following lines in system/fvSchemes to laplacianSchemes
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
and the following in system/fvSolution to solvers:
kFinal
        $alpha;
        tolerance       1e-10;
        relTol          0;
    epsilonFinal
        $alpha;
        tolerance       1e-10;
        relTol          0;
|  \\    /   O peration     | Version:  2.1.1                                 |
Build  : 2.1.1-221db2718bbb
Exec   : bubbleFoam
Date   : Jan 21 2014
Time   : 16:36:39
Host   : "markusUbuntuPC"
PID    : 8701
Case   : /home/markus/OpenFOAM/markus-2.1.1/run/bubbleColumnTutorial
nProcs : 1
Create time
Create mesh for time = 0
Reading g
Reading field alpha
Reading field p
Reading field Ua
Reading field Ub
Reading transportProperties
Calculating face flux field phia
Calculating face flux field phib
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    alphak          1;
    alphaEps        0.76923;
wallFunctionCoeffs
    kappa           0.41;
    E               9.8;
Reading field k
Reading field epsilon
Calculating field nutb
Calculating field nuEffa
Calculating field nuEffb
Calculating field DDtUa and DDtUb
Calculating field g.h
Courant Number mean: 0.053388 max: 0.207813
PIMPLE: Operating solver in PISO mode
Starting time loop
Time = 0.002
Max Ur Courant Number = 0.172395
DILUPBiCG:  Solving for alpha, Initial residual = 0.0021426, Final residual = 5.45235e-12, No Iterations 3
DILUPBiCG:  Solving for alpha, Initial residual = 8.98342e-05, Final residual = 1.63347e-12, No Iterations 3
Dispersed phase volume fraction = 0.36753  Min(alpha) = -0.0291739  Max(alpha) = 1.00075
DICPCG:  Solving for p, Initial residual = 6.61573e-05, Final residual = 5.80641e-06, No Iterations 3
time step continuity errors : sum local = 1.42929e-05, global = -1.2315e-06, cumulative = -1.2315e-06
DICPCG:  Solving for p, Initial residual = 1.14421e-05, Final residual = 9.11862e-11, No Iterations 65
time step continuity errors : sum local = 2.24465e-10, global = 4.65408e-12, cumulative = -1.23149e-06
DILUPBiCG:  Solving for epsilon, Initial residual = 0.999995, Final residual = 1.59838e-11, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 5.3506e-11, No Iterations 42
ExecutionTime = 0.05 s  ClockTime = 0 s
Courant Number mean: 0.0534269 max: 0.207502
Time = 0.004
Max Ur Courant Number = 0.167411
DILUPBiCG:  Solving for alpha, Initial residual = 0.00196793, Final residual = 6.01008e-12, No Iterations 3
DILUPBiCG:  Solving for alpha, Initial residual = 6.76905e-05, Final residual = 4.91127e-13, No Iterations 3
Dispersed phase volume fraction = 0.36753  Min(alpha) = -0.0172796  Max(alpha) = 1.00068
DICPCG:  Solving for p, Initial residual = 0.000147469, Final residual = 5.45488e-06, No Iterations 2
time step continuity errors : sum local = 1.35211e-05, global = 9.39624e-07, cumulative = -2.91871e-07
DICPCG:  Solving for p, Initial residual = 7.55098e-06, Final residual = 7.88894e-11, No Iterations 66
time step continuity errors : sum local = 1.95519e-10, global = 3.53133e-11, cumulative = -2.91835e-07
DILUPBiCG:  Solving for epsilon, Initial residual = 0.841785, Final residual = 4.05909e-11, No Iterations 8
DILUPBiCG:  Solving for k, Initial residual = 0.991263, Final residual = 4.04622e-11, No Iterations 53
ExecutionTime = 0.08 s  ClockTime = 0 s
Courant Number mean: 0.0534173 max: 0.207104
Time = 0.006
Max Ur Courant Number = 0.162844
DILUPBiCG:  Solving for alpha, Initial residual = 0.00195171, Final residual = 5.86516e-12, No Iterations 3
DILUPBiCG:  Solving for alpha, Initial residual = 6.08262e-05, Final residual = 9.84431e-11, No Iterations 2
Dispersed phase volume fraction = 0.36753  Min(alpha) = -0.0062796  Max(alpha) = 1.0006
DICPCG:  Solving for p, Initial residual = 8.24708e-05, Final residual = 6.16601e-06, No Iterations 2
time step continuity errors : sum local = 7.94365e-06, global = -2.95386e-07, cumulative = -5.87221e-07
DICPCG:  Solving for p, Initial residual = 1.91089e-05, Final residual = 7.95161e-11, No Iterations 66
time step continuity errors : sum local = 1.02443e-10, global = 8.20917e-12, cumulative = -5.87213e-07
DILUPBiCG:  Solving for epsilon, Initial residual = 0.677379, Final residual = 4.25709e-11, No Iterations 30
DILUPBiCG:  Solving for k, Initial residual = 0.896536, Final residual = 6.25555e-11, No Iterations 44
ExecutionTime = 0.11 s  ClockTime = 0 s
Courant Number mean: 0.053389 max: 0.206805
Time = 0.008
Max Ur Courant Number = 0.157728
DILUPBiCG:  Solving for alpha, Initial residual = 0.00193409, Final residual = 4.65798e-12, No Iterations 3
DILUPBiCG:  Solving for alpha, Initial residual = 5.91968e-05, Final residual = 8.86608e-11, No Iterations 2
Dispersed phase volume fraction = 0.36753  Min(alpha) = 0.00401149  Max(alpha) = 1.00056
DICPCG:  Solving for p, Initial residual = 0.000286388, Final residual = 2.81435e-05, No Iterations 8
time step continuity errors : sum local = 1.92615e-05, global = 6.51325e-07, cumulative = 6.41128e-08
DICPCG:  Solving for p, Initial residual = 8.11862e-05, Final residual = 9.94891e-11, No Iterations 73
time step continuity errors : sum local = 6.8192e-11, global = 5.36978e-12, cumulative = 6.41182e-08
DILUPBiCG:  Solving for epsilon, Initial residual = 0.129222, Final residual = 9.15914e-12, No Iterations 25
DILUPBiCG:  Solving for k, Initial residual = 0.757339, Final residual = 4.95247e-11, No Iterations 44
ExecutionTime = 0.13 s  ClockTime = 0 s
Courant Number mean: 0.0533735 max: 0.206451
Time = 0.01
Max Ur Courant Number = 0.156645
DILUPBiCG:  Solving for alpha, Initial residual = 0.00191571, Final residual = 5.1319e-12, No Iterations 3
DILUPBiCG:  Solving for alpha, Initial residual = 5.70908e-05, Final residual = 1.42504e-12, No Iterations 3
Dispersed phase volume fraction = 0.367529  Min(alpha) = 0.0136969  Max(alpha) = 1.00051
DICPCG:  Solving for p, Initial residual = 0.0279428, Final residual = 0.00133899, No Iterations 2
time step continuity errors : sum local = 0.00345412, global = 0.000955208, cumulative = 0.000955272
DICPCG:  Solving for p, Initial residual = 0.00157094, Final residual = 7.43963e-11, No Iterations 75
time step continuity errors : sum local = 1.71787e-10, global = 5.45734e-12, cumulative = 0.000955272
DILUPBiCG:  Solving for epsilon, Initial residual = 0.290322, Final residual = 3.03356e-11, No Iterations 15
DILUPBiCG:  Solving for k, Initial residual = 0.989327, Final residual = 4.09582e-11, No Iterations 103
ExecutionTime = 0.17 s  ClockTime = 0 s
Courant Number mean: 0.0535236 max: 0.206076
Time = 0.012
Max Ur Courant Number = 0.346255
DILUPBiCG:  Solving for alpha, Initial residual = 0.00205554, Final residual = 5.93573e-12, No Iterations 3
DILUPBiCG:  Solving for alpha, Initial residual = 7.4096e-05, Final residual = 1.86119e-13, No Iterations 3
Dispersed phase volume fraction = 0.367529  Min(alpha) = 0.0228536  Max(alpha) = 1.00047
DICPCG:  Solving for p, Initial residual = 0.905281, Final residual = 0.0282922, No Iterations 2
time step continuity errors : sum local = 0.0579972, global = 4.73252e-07, cumulative = 0.000955745
DICPCG:  Solving for p, Initial residual = 5.80309e-11, Final residual = 5.80309e-11, No Iterations 0
time step continuity errors : sum local = 0.0615709, global = -2.19258e-08, cumulative = 0.000955723
DILUPBiCG:  Solving for epsilon, Initial residual = 0.954852, Final residual = 5.33251e-13, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 0.00686899, No Iterations 1001
ExecutionTime = 0.28 s  ClockTime = 0 s
Courant Number mean: 0.125379 max: 6.10744
Time = 0.014
Max Ur Courant Number = 5.84605
DILUPBiCG:  Solving for alpha, Initial residual = 0.0944949, Final residual = 1.81182e-11, No Iterations 7
DILUPBiCG:  Solving for alpha, Initial residual = 0.204583, Final residual = 8.27286e-12, No Iterations 11
Dispersed phase volume fraction = 0.367529  Min(alpha) = 0.0235109  Max(alpha) = 2.333
DICPCG:  Solving for p, Initial residual = 0.996327, Final residual = 0.0813598, No Iterations 1
time step continuity errors : sum local = 2.42079e+11, global = -5.14632e+09, cumulative = -5.14632e+09
DICPCG:  Solving for p, Initial residual = 2.31678e-20, Final residual = 2.31678e-20, No Iterations 0
time step continuity errors : sum local = 3.13425e+12, global = -5.5099e+09, cumulative = -1.06562e+10
DILUPBiCG:  Solving for epsilon, Initial residual = 0.262546, Final residual = 0.000207751, No Iterations 1001
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 7.34295e+07, No Iterations 1001
ExecutionTime = 0.5 s  ClockTime = 1 s
Courant Number mean: 1.8631e+12 max: 1.31834e+15
Time = 0.016
Max Ur Courant Number = 2.49974e+15
DILUPBiCG:  Solving for alpha, Initial residual = 0.998815, Final residual = 3.6838e-11, No Iterations 120
DILUPBiCG:  Solving for alpha, Initial residual = 1, Final residual = 1.63103e-11, No Iterations 51
Dispersed phase volume fraction = -1.35014e+24  Min(alpha) = -1.50905e+27  Max(alpha) = 2.04827e+26
DICPCG:  Solving for p, Initial residual = 1, Final residual = 3.40176e+20, No Iterations 1001
time step continuity errors : sum local = 1.52312e+59, global = 2.12901e+42, cumulative = 2.12901e+42
DICPCG:  Solving for p, Initial residual = 0.000401859, Final residual = 9927.39, No Iterations 1001
time step continuity errors : sum local = 7.30319e+98, global = -6.49763e+82, cumulative = -6.49763e+82
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
 at ??:?
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
setzberg is offline   Reply With Quote
Old   January 21, 2014, 11:34
Nima Samkhaniani
nimasam is on a distinguished road
your case is diverging ,you may want to play with your BC and your schemes
for Schemes i suggest to use an upwind (bounded scheme for k and epsilon)
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 23, 2014, 06:15
Thanks for your reply! I also think that there is a problem with BC. The diverging Courant number is a problem, which occurs in several other threads. But there is also no hint how to solve this.
http://www.cfd-online.com/Forums/ope...ubblefoam.html
http://www.cfd-online.com/Forums/ope...lent-case.html
http://www.cfd-online.com/Forums/ope...rial-case.html
Can anyone tell me, how to change the BC so that the tutorial case works with turbulent flow? Or if the BC are not the problem, what has to be changed then? I already tried to change the scheme as nimasam suggests, but this does not prevent the Courant number to diverge.
Old   January 23, 2014, 06:34
Nima Samkhaniani
whats ur BC for k and epsilon?
Old   January 23, 2014, 06:56
These are the BC as given in the tutorial case bubbleFoam
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.0002;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.0002;
    outlet
        type            inletOutlet;
        inletValue      uniform 0.0002;
    walls
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1e-8;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 1e-8;
    outlet
        type            inletOutlet;
        inletValue      uniform 1e-8;
        value           uniform 1e-8;
    walls
        type            zeroGradient;
    defaultFaces
        type            empty;
Do I have to use kqRWallFunction and epsilonWallFunction?
Old   January 23, 2014, 11:23
Nima Samkhaniani
well, how did you calculate inlet values for k and epsilon? you can also use wallFunctions for wall patches.
Old   October 15, 2015, 13:29
Default BubbleFoam limitations
masoudsh is on a distinguished road
I want to use bubblefoam solver but it prevents on my work, because of bubblefoam limitations.
The diameter of the particles constituting the dispersed phase is assumed to be consistent. Aggregation, breakage and coalescence phenomena are not accounted for.
What is your suggestion?
DO you know any solver uses Euler mixture model ?
thank you
masoudsh is offline   Reply With Quote
of2.1
Propeller case in AMI tutorial reza1980 OpenFOAM Running, Solving & CFD 68 November 28, 2017 21:37
Launder Shrma Low Reynolds turbulence model case setup sivakumar OpenFOAM Pre-Processing 3 September 14, 2013 08:20
pisoFoam elbow case with turbulence inf.vish OpenFOAM Running, Solving & CFD 0 August 19, 2013 05:17
Propeller tutorial case enquiries chujeh2020 OpenFOAM 0 August 26, 2012 01:18
Request for pipe bifurcation fluent tutorial case Giorgos Momferratos FLUENT 0 October 20, 2008 15:10
