Upwind-like flux scheme on Central Foam
Old   February 11, 2014, 02:19
Default Upwind-like flux scheme on Central Foam
Ashwani
AshwaniAssam is on a distinguished road
Dear all,
Is implementing an upwind-like flux scheme in rhoCentralFoam, will be easier. Can anyone has any experience with it.
I have looked at the following link: http://www.cfd-online.com/Forums/ope...-openfoam.html
But I need more reference. I am trying to implement AUSM scheme only. I am very new to OpenFoam. While running the wedge problem I am getting the following error.
Mean and max Courant Numbers = 0.5 0.5
Time = 0.002
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
ExecutionTime = 1.67 s ClockTime = 2 s
Time = 0.0021
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /home/Ashwani/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/Ashwani/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/Ashwani/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/Ashwani/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/Ashwani/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/home/Ashwani/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/rhoAUSM"
#5 __libc_start_main in "/lib64/libc.so.6"
Aborted (core dumped)
Thanks.
AshwaniAssam is offline   Reply With Quote
Old   February 14, 2014, 04:51
Default Re
Ashwani
Any help?? Even with the errors.
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Display regions central linear and upwind for gamma scheme braennstroem OpenFOAM Post-Processing 3 May 28, 2008 03:49
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
