SIMPLE vs LAPLACE
Old   November 18, 2013, 05:45
Default SIMPLE vs LAPLACE
Lionel R.
lionelr is on a distinguished road
Dear all,
I'm working on optimizing OpenFOAM execution speed using GPU. For now I use Paralution (see http://www.paralution.com/) and it works fine. The OpenFOAM plugin example they provide uses a Laplacian (fvm::laplacian(DT, T)) algorithm and allows a speedup up to 7x comparing to the CPU only execution time on our testbed.
When I test Paralution with the SIMPLE algorithm on a backward facing step test case, we don't have any speedup comparing to the CPU execution.
I suspect an I/O overhead with the SIMPLE algorithm. In both cases, the solver is a PCG.
My questions are :
(1) Have you some explanations of that phenomena ?
(2) Have you some tips on how to get ride of this problem ?
Thanks and best regards,
Lionel
lionelr is offline   Reply With Quote
Old   February 28, 2014, 11:47
Default paralution openmp backend
Hassan
luckycfd is on a distinguished road
I compiled paralution-0.5.0 correctly and my openfoam is 2.1.x.
To test the solver, I use the OpenFOAM plugin example, Laplace. but I don't have any speedup by openmp backend!
I attached the my laplace folder, please guide me how can I configure this example for getting speed up bye openmp threads?
I set number of openmp threads in the shell by:
export OMP_NUM_THREADS=2
is it correct for setting the number of openmp threads for paralution?
my system have 8 x six-core (NUMA) = 48 core no hyper threading.
regards
Hassan
luckycfd is offline   Reply With Quote
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 01:38
Making SIMPLE converge faster Fabio Main CFD Forum 4 April 9, 2006 11:35
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
