March 18, 2014, 13:42 |
Foam-3.0-ext + MixingPlane Problems
sirLentschi
Rep Power: 15 |
Hello community,
I have 2 perfectly matching and non-rotating/moving blocks, which are coupled by a mixingPlane Interface. During calculation I always get an Floating Point Exception error. I have tried many different settings (and copied the settings from a mixingPlane tutorial) but get this error again: Create mesh for time = 0 Initializing the mixingPlane interpolator between master/shadow patches: STAT1/STAT2 Reading field p Reading field U Calculating potential flow CG: Solving for p, Initial residual = 1, Final residual = 0.00992722, No Iterations 82 continuity error = 9.22837e-06 Floating point exception (core dumped) My boundary file looks like this: 6 ( INLET { type patch; nFaces 171; startFace 27788; } STAT1 { type mixingPlane; nFaces 171; startFace 27959; shadowPatch STAT2; zone STAT1ZONE; coordinateSystem { type cylindrical; name mixingCS; origin (0 0 0); e1 (0 0 1); //Direction of Streamlines in z-Direction e3 (1 0 0); } ribbonPatch { sweepAxis Theta; stackAxis Z; discretisation bothPatches; } } WALL1 { type wall; nFaces 1624; startFace 28130; } OUTLET { type patch; nFaces 171; startFace 29754; } STAT2 { type mixingPlane; nFaces 171; startFace 29925; shadowPatch STAT1; zone STAT2ZONE; } WALL2 { type wall; nFaces 1624; startFace 30096; } ) The mesh is ok, as can be seen in checkMesh: Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Area [m^2] Surface topology INLET 171 200 0.1 ok (non-closed singly connected) STAT1 171 200 0.1 ok (non-closed singly connected) WALL1 1624 1680 6.6 ok (non-closed singly connected) OUTLET 171 200 0.1 ok (non-closed singly connected) STAT2 171 200 0.1 ok (non-closed singly connected) WALL2 1624 1680 6.6 ok (non-closed singly connected) Checking geometry... This is a 3-D mesh Overall domain bounding box (-3.46945e-18 -2.77556e-17 0) (0.1 1 6) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (5.95673e-17 -9.5346e-18 2.69053e-18) Threshold = 1e-06 OK. Max cell openness = 1.96445e-16 OK. Max aspect ratio = 13.0944 OK. Minumum face area = 0.0001. Maximum face area = 0.0140221. Face area magnitudes OK. Min volume = 2e-06. Max volume = 0.000160253. Total volume = 0.6. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.24444e-09 OK. Mesh OK. Has anyone an idea to solve this problem? Thanks in advance. Regards, Markus Last edited by lentschi; March 31, 2014 at 08:46. |
March 19, 2014, 04:02 |
sirLentschi
Rep Power: 15 |
Problem solved!
Definition problem in the boundary file! |
March 22, 2014, 10:27 |
hi don lenardo,
I am using MRFSimpleFoam, 1/8 th of the fan. So far I am using Conformal Mesh, but now I want to reduce the computational time by using AMI interface, my questions are: is it possible in MRFSimpleFoam? I have attached the fig, please have a look. (the fan is in the middle) I have edited (manually, I didt use createPatch utility) as follows: constant/polyMesh/boundary AMI4 { type cyclicAMI; nFaces 13000; startFace 40391000; neighbourPatch AMI3; bridgeOverlap false; } AMI3 { type cyclicAMI; nFaces 26000; startFace 40404000; neighbourPatch AMI4; bridgeOverlap false; } AMI2 { type cyclicAMI; nFaces 23400; startFace 40430000; neighbourPatch AMI1; bridgeOverlap false; } AMI1 { type cyclicAMI; nFaces 13000; startFace 40453400; neighbourPatch AMI2; bridgeOverlap false; } when I run check Mesh, I am getting the warning message as you given in the first post. Can you please help me solve the problem? I am using OF-2.1.1 mixing plane, is it available in OF2.1.1? can you please explain the procedure? kind regards, Sivakumar Last edited by sivakumar; April 1, 2014 at 04:21. |
March 31, 2014, 08:40 |
sirLentschi
Rep Power: 15 |
Hello Sivakumar,
Mixing Plane is not available in OF 2.1! Re-check your boundary file - maybe the boundaries are incorrectly defined and AMI 1 is not the neighbour of AMI2 (and AMI3 to AMI4 respectively). Additionally, you have to add the following lines to each AMI-boundary: transform noOrdering; matchTolerance 0.001; Hopefully this will help! //Markus |
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen | su_junwei | OpenFOAM Meshing & Mesh Conversion | 2 | July 26, 2008 23:58 |
[OpenFOAM] Problems using paraview 244 under open FOAM 141 or 13 | sergio | ParaView | 0 | March 13, 2008 13:52 |
[Commercial meshers] FOAM FATAL ERROR points deallocated | hoerl | OpenFOAM Meshing & Mesh Conversion | 0 | October 30, 2006 07:47 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
FOAM licensed free to academic institutions | Nabla Ltd. | Main CFD Forum | 0 | November 18, 2002 10:24 |
