April 23, 2014, 14:11 |
pimpleFoam strange results
Giampaolo Cetraro
Rep Power: 13 |
hello everyone,
I'm solving the laminar flow around a flat plate at 4deg angle of attack with pimpleFoam. I got strange results, do you know where they might come from? case 102 nOuterCorrectors 3 nCorrectors 2 nNonOrthogonalCorrectors 2 Courant max = 0.5 case 104 nOuterCorrectors 6 nCorrectors 2 nNonOrthogonalCorrectors 2 Courant max = 10 case 106 nOuterCorrectors 6 nCorrectors 2 nNonOrthogonalCorrectors 2 Courant max = 5 The case 104, seems to be better than 102, because I added more nOuterCorrectors (but a very high Co) But in case 106, with the same correctors and half Co, again the flow field is totally weird... Any hint? |
April 24, 2014, 17:59 |
Joachim Herb
Rep Power: 21 |
Try much larger nOuterCorrectors and add residual control, see e.g. https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution
(this is the only example in the tutorials using it, so don't care about the different solver rhoPimpleFoam) |
Modifying sonicFoam to run with variable timestep - strange results | dalaron | OpenFOAM Programming & Development | 1 | September 2, 2013 07:21 |
Strange DNS results | LijieNPIC | OpenFOAM | 14 | June 14, 2011 04:30 |
upwind schema strange results; Solution of Versteeg example differs from OpenFOAM sol | idrama | OpenFOAM | 12 | May 10, 2011 05:38 |
Newton Raphson - strange results | Bren | Main CFD Forum | 5 | February 11, 2009 10:47 |
Slip boundary condition giving strange results | hemph | OpenFOAM Running, Solving & CFD | 3 | January 18, 2007 05:15 |
