error running Allrun script
Old   May 1, 2014, 20:45
Default error running Allrun script
jul059 is on a distinguished road
hello,
I am new to linux and OpenFOAM. I'm trying to run the motorBike tutorial. When I try to run it with sudo ./Allrun, I get the following error :
./Allrun: 3: .: Can't open /bin/tools/RunFunctions
I understand this can be a problem with the variable $WM_PROJECT_DIR. Here's what I get with echo $WM_PROJECT_DIR :
/opt/openfoam211
So, anyone knows why I get this error?
jul059 is offline   Reply With Quote
Old   May 2, 2014, 03:47
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
did you do
$ source /opt/openfoam211/etc/bash
before running the script? If yes, show, please, your environment with a command
$ export | grep -E '(WM_|FOAM_)'
to see if it really set up.
alexeym is offline   Reply With Quote
Old   May 2, 2014, 08:11
Thanks for the help. Here's what I get with this command :
declare -x FOAM_APP="/opt/openfoam211/applications"
declare -x FOAM_APPBIN="/opt/openfoam211/platforms/linux64GccDPOpt/bin"
declare -x FOAM_EXT_LIBBIN="/opt/ThirdParty-2.1.1/platforms/linux64GccDPOpt/lib"
declare -x FOAM_INST_DIR="/opt"
declare -x FOAM_JOB_DIR="/opt/jobControl"
declare -x FOAM_LIBBIN="/opt/openfoam211/platforms/linux64GccDPOpt/lib"
declare -x FOAM_MPI="openmpi-system"
declare -x FOAM_RUN="/home/julien/OpenFOAM/julien-2.1.1/run"
declare -x FOAM_SETTINGS=""
declare -x FOAM_SIGFPE=""
declare -x FOAM_SITE_APPBIN="/opt/site/2.1.1/platforms/linux64GccDPOpt/bin"
declare -x FOAM_SITE_LIBBIN="/opt/site/2.1.1/platforms/linux64GccDPOpt/lib"
declare -x FOAM_SOLVERS="/opt/openfoam211/applications/solvers"
declare -x FOAM_SRC="/opt/openfoam211/src"
declare -x FOAM_TUTORIALS="/opt/openfoam211/tutorials"
declare -x FOAM_USER_APPBIN="/home/julien/OpenFOAM/julien-2.1.1/platforms/linux64GccDPOpt/bin"
declare -x FOAM_USER_LIBBIN="/home/julien/OpenFOAM/julien-2.1.1/platforms/linux64GccDPOpt/lib"
declare -x FOAM_UTILITIES="/opt/openfoam211/applications/utilities"
declare -x WM_ARCH="linux64"
declare -x WM_ARCH_OPTION="64"
declare -x WM_CC="gcc"
declare -x WM_CFLAGS="-m64 -fPIC"
declare -x WM_COMPILER="Gcc"
declare -x WM_COMPILER_LIB_ARCH="64"
declare -x WM_COMPILE_OPTION="Opt"
declare -x WM_CXX="g++"
declare -x WM_CXXFLAGS="-m64 -fPIC"
declare -x WM_DIR="/opt/openfoam211/wmake"
declare -x WM_LDFLAGS="-m64"
declare -x WM_LINK_LANGUAGE="c++"
declare -x WM_MPLIB="SYSTEMOPENMPI"
declare -x WM_OPTIONS="linux64GccDPOpt"
declare -x WM_OSTYPE="POSIX"
declare -x WM_PRECISION_OPTION="DP"
declare -x WM_PROJECT="OpenFOAM"
declare -x WM_PROJECT_DIR="/opt/openfoam211"
declare -x WM_PROJECT_INST_DIR="/opt"
declare -x WM_PROJECT_USER_DIR="/home/julien/OpenFOAM/julien-2.1.1"
declare -x WM_PROJECT_VERSION="2.1.1"
declare -x WM_THIRD_PARTY_DIR="/opt/ThirdParty-2.1.1"
Old   May 2, 2014, 09:49
Alexey Matveichev
Well, environment variables are correct. Don't know, maybe they weren't set up in the terminal where you've executed Allrun script.
Old   May 3, 2014, 15:27
I forgot to say,
gives the following error :
bash: /opt/openfoam211/etc/bash: No such file or directory
Old   May 3, 2014, 16:06
Alexey Matveichev
Oh, sorry, maybe it's autocorrect but the right command is
source /opt/openfoam211/etc/bashrc
Old   May 3, 2014, 23:45
I ran
and the result is the same.
When I run
sudo ./Allrun
I get the following :
But if I run it without sudo, I get the following :
cp: cannot create regular file `constant/triSurface/motorBike.obj.gz': Permission denied
blockMesh already run on /home/julien/OpenFOAM/julien-2.1.1/run/incompressible/simpleFoam/motorBike: remove log file to re-run
snappyHexMesh already run on /home/julien/OpenFOAM/julien-2.1.1/run/incompressible/simpleFoam/motorBike: remove log file to re-run
potentialFoam already run on /home/julien/OpenFOAM/julien-2.1.1/run/incompressible/simpleFoam/motorBike: remove log file to re-run
simpleFoam already run on /home/julien/OpenFOAM/julien-2.1.1/run/incompressible/simpleFoam/motorBike: remove log file to re-run
How do we explain that the script seems to execute further without sudo?
As I said, I am new to OpenFOAM AND Linux...
Old   May 4, 2014, 02:43
Alexey Matveichev
Well, you've got 2 problems here
1. If you run Allrun with sudo, script has different set of environment variables
2. You don't have write permission in /opt/openfoam211/tutorials
So you can do something like this:
$ source /opt/openfoam211/etc/bashrc
$ cd $FOAM_RUN
$ cp -r $FOAM_TUTORIALS .
$ cd tutorials
$ ./Allrun
These commands will copy tutorials folder for your home folder where you have write permission, and after you'll be able to run them.
Old   May 5, 2014, 17:31
I was finally able to run the script. The source of my problem was rather obscure : a faulty hard drive. I replaced it, reinstalled CAELinux and everything is fine.
Thank you for your help!
script Allrun doesn't work after beeing copied on another disk hard drive nakor OpenFOAM Installation 3 September 12, 2012 15:16
Trying to understand Allrun script j-avdeev OpenFOAM Running, Solving & CFD 4 November 16, 2011 02:47
How can i activate the Allrun script? spk OpenFOAM 2 October 2, 2011 17:28
Ubuntu: Allrun script issue fletc900 OpenFOAM Bugs 2 July 2, 2010 16:58
Empty Allrun script mwild OpenFOAM Bugs 4 August 25, 2009 02:43
